Tazer question
funglenn
Glenn
Maryland
2020 JLUS North Edition
I am on the fence about buying a tazer and have seen it will do a few things that i care about:
1. make it so i do not have to constantly turn off the stop/start
2. disable the safety that stops me from reversing with the door open.
Does it have any ability to stop the automatic cruse control from disabling after coming to a stop for 2 seconds?
Ideally, i want it to be like my BMW, it just stays at a stand still until traffic moves forward again, instead of disabling. NO matter how long it takes.
thanks
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
No, it doesn't. My RS-5 did the same thing, but after 12 seconds.
It does, however, do things like letting you use your garage door opener for a while after turning off the Jeep, turn assist for stupidly sharp turns on the trail, etc.
miner3649er
Colleyville, TX
2021 Wrangler Rubicon 4 Door Eco Diesel
It was as cheap to get a Tazer to adjust my tire size so my speedo reads right as getting the dealer to do it just once. Keep in mind if I ever change tire brands the tire height might be slightly different. So this was a no brained for me. I also used it to turn off the ESS.
bjm00se
JLUR 6sp ordered 11/3/21, picked up 8/30/22
I need that. How do you do it? What is the feature name called?
Ratbert
PNW
Software Engineer
Search for Homelink in their manual. You can set it to 30 secs after shutting off the engine or 30 secs after opening the door.
bjm00se
Perfect. Sometimes, you just need to know the keyword to look for.
wibornz
Ted
lansing, Mi.
www.instagram.com
JL Unlimited Rubicon
The best thing about the Taser is being able to clear a code that puts you in limp mode. Being 70 miles off the closest hard surface road and over a hundred miles to the closest Jeep dealership to get out of limp mode is not ideal. It is so much better to reset the code and continue on.
I love the Taser and use many of the functions. Like engage the front locker only. winch mode, disable the sway bar in 2wd and drive over 20 mph. change tire size, change gear size, enable my fog light to stay on with the bright lights on, make my passenger seat heat come on with remote start, be able to engage the rear locker in 2wd, able to engage the lockers in 4hi. turn off the seat belt ding, turn off the auto stop/start, I am sure there is more, I just don't want to think that hard this morning.
