Tailgate sagging
snelson438
Rhode Island
Jeep wrangler unlimited JL
i have a JL and I just noticed today that the tailgate may have a slight sag to it. The inside of the tailgate door appears to be striking the inside of the body on the wrangler when closing. I need to lift the door slightly when closing to prevent this. Is this a problem I can fix or something that a dealer needs to look at? Can’t figure out where I’d adjust the hinges. Thanks.
DogplasmaPeopleplasma
Medford, NJ
2014 4Runner Trail Premium....2021 JLUR
See if you can find the instructions on how to install the Mopar tailgate reinforcement bracket. You have to remove and loosen some of the bolts while wedging a piece of cardboard to hold the tailgate up while closed. That may help make what you are experiencing a little better. The instructions are visual and will make more sense vs trying to explain.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
After fixing the issue consider the following to try to not repeat the issue in the future:
What size tires are you running?
Do you have the heavy duty hinges?
snelson438
Rhode Island
Thanks for the info everyone. Tires are factory, I think 17 inch? No heavy duty hinges, just factory.
rickinAZ
Rick
Phoenix
2026 MOAB 392
Most of us run 17" wheels, regardless of tire size, and they don't tend to vary that much in weight. Upsized tires are where the weight is added. The tires' sidewall marking, while cryptic-looking, will give you the size.
