Synergy castle nuts
MrFenderpicks
Ivan
Houston, TX
2020 Rubicon
While installing my Synergy draglink
I managed to screw up the castle nut on the side that goes to my pitman arm
does anyone know what size and where I can find some alternative until I can get some actual synergy replacement parts
77RRAD
Ron
Las Vegas
2019 JLUR
I believe the synergy tie rod ends are GM 1 tons. may be able to get them from a auto parts store.
Id take it to the auto part store to check.
Ron
PIG
Rock Sponsor (Level 1)
SLO, CA
18' JL
Brian0128
Annapolis, MD
2019 JLUR, 2018 Toyota TRD PRO
Engineer
The drag link ends are 1-14 left hand thread. It should be easy enough to find those in a hardware store.
4162-LHD Tie Rod End, Left Hand Thread for JL Drag Link (Single Plane)1-14 Left Hand
4163-LHD Tie Rod End, Left Hand Thread for JL Drag Link and Tie Rod1-14 Left Hand
Dave928
Washington
2020 JLU Rubicon, 03 Silverado, 88 Porsche 928 S4
Aircraft Tech
How do you mess up a castellated nut?
MrFenderpicks
MrFenderpicks
Ivan
Houston, TX
2020 Rubicon
The one that goes to the pitman arm
Torque it to 55Ft lb, and was never able to align the hole to put the cotter pin thru.
Kept tightening it , didnt work, and it just got to the point where the thread was screwed up
D60
CO
JL
Wow, I want your hardware stores. A true fastener house would likely have basic nuts (but almost surely not castle-ated), but a left hand 1" anything wouldn't be found at an Ace Hardware, etc around here.
OP, if you can source a graded nut in the thread you need a machinist can add the windows relatively easily with a collet block in a mill.
According to RA listings an '80 Chevy K30 uses 1-18
MrFenderpicks
MrFenderpicks
Ivan
Houston, TX
2020 Rubicon
Thanks for the input.
Back in stock as of this AM, FYI
If you had an open order it will ship before the end of the week,
Who can i call to order them and overnight this sucker?
