Snapped off Castle nut, need to replace ball joint bolt
MileHigh
Kraig
Denver, Colorado
2018 Jeep Wrangler JL Rubicon Unlimited
I snapped off the castle nut on the bottom of my drivers side ball joint. There is actually a little bolt still showing. I was wondering how hard or easy it is to replace this bolt. Something I can do in the field with just a jack and removing the tire? Is the bolt threaded through the aluminum piece just above the castle nut at the bottom? Just looking for some advise on how it all goes together and how easy it would be to replace that bolt. Thanks for your help and info!
YJA
San Diego, CA
2020 JLUR, 1988 YJ, 1983 CJ-7
Unfortunately you have to replace the entire ball joint, which requires removing the tire/wheel, hub/knuckle, and axle shaft. You could do it in the field if you had to. Aside from a jack and hand tools the only special tool you'll need is a Ball Joint Press.
Moto_21
Erik
Corona
2018 JLU Sport
Maintenance
Damn what did you torque it with a pry bar?
