JL Nut & Bolt Sizes
Rufus
NYC
2018 2 door JL Sport 3.6 V6
How about the nuts on the terminals of the electrical bus bar next to the PDC?
jlewissystem
J
STL
2019 JLUR MANUAL Mojito!
This is great information. Thank you for posting, but for the torque values can you tell me the number after the "+" sign mean?
The second number is “degrees”, suggested as turn “x” amount degrees extra, after proper torque is achieved.
Arrowhead
George
Stillwater, NY
2018 Wrangler JL Sport
Rufus
NYC
From @Jebiruph
“N1, N2 and main baterry negative are M6x1.0
Aux battery negative is M8x1.25
Some have bought wingnuts that were too wide. All the ones I bought fit between the post, but you may have to back the first one off a little until the second one is on.”
El Jefe
Beautiful Colorado
Several
Those specs (other than the lug nut reference) are for a JK. Much of the JL hardware is different (mostly larger - i.e. shocks are 18mm not 13mm, upper track bars are 18mm not 15mm etc.)
Does anyone have a complete, updated list for the JL?
oceanblue2019
Northern Arizona
2019 JLUR 2.0L Auto
Consultant
Also if you swap out suspension components you will find a lot use SAE hardware versus metric. So you quickly end up needing both metric and SAE but note that some do cross over.
Also think through what you can/will tackle on the trail versus not. As a guy who just needed a tow home it has caused me to rethink what I carry.
blnewt
New Mexico
Just ask @cosine he knows!
This^^^If you're doing the work at home, try SAE if you get some slop w/ metric sockets/wrenches. I've found a few cases where Metrics aren't a tight fit, and especially the lower control arms that are high torque fasteners, sure don't want to round off bolt heads at 190 ft lbs :(
Odyssey USA
Daniel
Indiana
www.youtube.com
2021 JLU Rubicon
Bumping this back up just in case someone can think of any other useful socket sizes or even if a wrench etc would be better for a particular fastener due to space constraints.
garykk
Gary
Southern NM
2022 JLURD
Don’t forget a set of Torx screwdrivers or Torx sockets.
