Sway Bar Quick Disconnect Recommendations?
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
Oh MC are that cheap? Well shoot sign me up. Quick question: does disconnecting sway bars result in your tires traveling UP more? I know it allows for greater flex down, but what about a wheel going up? I have concerns about it hitting my fender liner
Articulation always work both ways.. If one tire travels down, the other tire must travel up, as it is always the case with a solid axle.
oceanblue2019
Northern Arizona
2019 JLUR 2.0L Auto
Consultant
Well, there is one other possibility but it means you're having a bad bad day and going to be walking home
Scooter2
Socal/ Northern Colorado
2018 JL Sport / 2022 F250 / 2023 Bronco Wildtrak
I did them last weekend. All super simple except for the passenger side sway bar relocation bracket. I think the factory weld was off by an 1/8 of an inch and really had to hammer on it to get into place. They are easy to disconnect and the ride fees much better without sway bar links that are to short.
You used relocation brackets on both passenger and driver side correct? These links are going to put my sway bar at a pretty steep angle (Have yet to install them). Maybe it doesn’t mater?
mgroeger
Southern UT
2021 JLUR 2.0T
You used relocation brackets on both passenger and driver side correct? These links are going to put my sway bar at a pretty step angle (Have yet to install them). Maybe it doesn’t mater?
5 to 10 degrees above horizontal is considered ideal. Many go above that simply because, like you are seeing, the aftermarket discos can really pitch them up and that is because that disco needs to cover anywhere from a 2" to 6" lift.
Both our JLs are running with the sway bar pitched pretty high and we have no problems. I'm told it would be an issue for the TJs but not the JK and JLs.
entropy
Foothills of the San Gabriels
OF top 1% content creator
Any news on disconnects? All I've seen is massive links that require you to have a wrangler touching the clouds or some that require you to chop off your jeep. Teraflex claims they tested theirs with all JL models, including sport, but those links are almost as long as (thats whay she said).
For us mortals who off-road on trails but do not rock crawl, are we still stuck with a wrench set as our only option?
Laying on the dirt or pavement with a wrench sucks, and sometimes the bolt is hard to get back in. And I feel like throwing up anytime one of my tires is hanging on the air unnecessarily.
Pig-Pen
Banned Camp
2018 JLU
jabroni
i use a ratchet and a battery powered ratchet. takes the bolts out in about 30 seconds. for lining back up to reinstall, just have to be on pretty level ground, same as with disconnects.
Arterius2
Jerry
Vancouver, BC
Lying on the dirt or pavement with a wrench sucks, and sometimes the bolt is hard to get back in. And I feel like throwing up anytime one of my tires is hanging on the air unnecessarily.
If you can handle chopping off a tab, which to be honest is really not a big deal.
Then these are probably exactly what you are looking for.
https://jksmfg.com/i-24048425-flex-connect-end-link-master-kit-jt-jl.html?ref=category:1205540
Jeep Wrangler JL Sway Bar Quick Disconnect Recommendations? FA4F46F8-78E7-4CF8-A3F5-FC81593D7994
Here, let me hold your hands while I was getting mine chopped off.
Jeep Wrangler JL Sway Bar Quick Disconnect Recommendations? 568741BC-E5D1-4C57-9C2E-5A53CD7528D2
Pig-Pen
Banned Camp
2018 JLU
jabroni
do you have the flex connect version? im not sure i understand the point of those. theyre adjustable so you can make the ride softer or firmer? from a sway bar end link?
Arterius2
Jerry
Vancouver, BC
I don’t have the flex version, but apparently they are designed to allow some degree of articulation in the links themselves without actually disconnecting them. Sort of like the Antirock sway bar but allows more degree of adjustments.
Odyssey USA
Daniel
www.youtube.com
2021 JLU Rubicon
I only watched one video review of these flex connect end links. Basically, it seems the springs that take a few minutes to swap out, might change ride quality, not sure. They swapped springs and got no extra travel. It was best disconnected of course.
entropy
Well that's it. Having a SFA with no sway bar disconnect makes no sense, even at JL sport stock height, which is about the same as a JK rubicon. And disconnecting by hand is a royal pain in the ass, last time took me over 15 mins at least if not half an hour, and then getting them back on... I pulled the trigger on the JKS and got all the tools for greasing the bearings and the angle grinding to chop off that damn bracket.
There's no going back I guess.
Odyssey USA
Daniel
www.youtube.com
2021 JLU Rubicon
I’ve had that exact thought. Unless you disconnect, there’s no SFA benefit. Am I missing something? Otherwise, manual disconnects and fighting with them might be the only option I guess.
entropy
You still get slightly better articulation as well as other pros with a SFA vs. independent. But you are missing all of the articulation potential with the sway bar connected. And it is a relatively cheap upgrade.
This video explains why SFA is so much better, articulation is only one variable in the equation:
