Sway Bar Quick Disconnect Recommendations?
mgroeger
Southern UT
2021 JLUR 2.0T
SmoothJeepOperator
Richmond VA
2018 JLU Wrangler Sport
Dang, you can get a RockJoack or AntiRock for $200 less and those are well known established brands for those kits.
This is a bit different from my understanding but still crazy expensive. I do like that it can be air actuated though.
mgroeger
Southern UT
2021 JLUR 2.0T
Gotcha. At the end of the day it seems like the good old manual disconnect wins because it's WAY cheaper and then you get the absolute most articulation since there is no physical connection what so ever.
We are running the MC discos on my wife's Jeep and it literally takes me 60 seconds to disco and if we are flat another 60 seconds to reconnect. Running a 3.5" lift vs. the 2.5" spacer lift went a LONG way to making it easier. The higher you go the easier to disco.
SmoothJeepOperator
Richmond VA
Any cutting required for the mc one on the non rubi models? Forgive if you already shared that info.
mgroeger
Southern UT
2021 JLUR 2.0T
Nope, that's what I liked about them but I don't think they make ones for the smaller lifts.
SmoothJeepOperator
Richmond VA
Nice yea I'm looking at a 2.5 inch lift to replace my rc spacer lift. Figured might as well do the quick discos now. Might have to grab these. Thanks
mgroeger
Southern UT
2021 JLUR 2.0T
Just a heads up, MC only makes one disco and they are long. Even with a 3.5" lift they pitch the sway bar up pretty high but it's still OK. I don't know that I would use them for a 2.5" lift. Personally, having run the JKS ones, I do not recommend them. I was unimpressed, which was odd because I loved them on my '04 LJ. Do some research and see what else is out there.
jeepoch
Jay
Longmont, CO
2019 JL Wrangler Sport S 3.6L Auto 2 door, 2.5" lift, 35s
I'm going to try the Teraflex JL / JT Sway Bar Quick Disconnect Kit (SKU #1764000).
I like the fact that there is no cutting, everything disconnects and reconnects really easy on both sides and the sway bar is held well out of the way when disconnected.
Purchased the kit based on concept since I couldn't find any reviews. Haven't installed it yet. Any one else have any opinions on this approach?
https://teraflex.com/shop/category?utf8=âś“&q=1764000&view=6
Jay
jeepoch
Jay
Longmont, CO
How much of a lift are you putting on the Jeep? I heard from another poster that the Teraflex ones are like the MC ones in that they pitch the sway bar pretty high.
I have a Mopar Lift that gave me a little over 2.5". I'm running 35's which give me about 4" total over stock (31.5s) when aired down to 15 and about 4.5" when aired up to 36 psi.
Jay
Jeep Wrangler JL Sway Bar Quick Disconnect Recommendations? IMG_20200801_200145
mgroeger
Southern UT
2021 JLUR 2.0T
Jay
OK, just note that both the Teraflex and MC will pitch the sway bar upwards but it's not an issue. A 2.5" Mopar is more like a 3" at least on a Sport.
mgroeger
Southern UT
2021 JLUR 2.0T
Jay
Nice looking Jeep BTW :)
Maverick909
I.E.
www.instagram.com
I gotta say the ride is so much better without the sway bar connected. I never wanted to fuss with the bolt and but when wheeling down I always left it connected. Finally added JKS quick disco little bit of a pain to get off and on but I’m sure they’ll get a little easier as I learn the tricks of it. Highly recommend them
mgroeger
Southern UT
2021 JLUR 2.0T
The ride is way better but it is also way safer. Without that disconnected you can get into a tip over situation where if it was disconnected it would simply be a full articulation situation.
aldo98229
Aldo
Bellingham, WA
Market Research
I only watched one video review of these flex connect end links. Basically, it seems the springs that take a few minutes to swap out, might change ride quality, not sure. They swapped springs and got no extra travel. It was best disconnected of course.
LOL...famous last words.
I received my Flex Connect this morning. I have been trying ALL DAY to open the damn thing to get to the springs. I haven't been able to.
The instructions show how to open it, but they way it is designed makes it impossible to get the necessary leverage to open the stupid thing.
It is an excellent idea that has been poorly executed, IMO.
I sent an email to Northridge 4X4 to see if they know of a trick. If not, it is going back.
