Sway bar quick disconnect best recommendations?
Jessicuhhh_11
Jessica
Wichita, KS
JLU Sahara
Trying to currently finish up an install of a JKS J-connect 3.5 in lift on my JL sahara. This lift required cutting of the pass side sway bar disconnect bracket. i do not want to cut anything so looking for some recommendations for other sway bar quick disconnects that we plug & play with this lift. Thanks!
TrailMax
Max
Arkansas
2023 Wrangler High Altitude 4xe
azwjowner
Phoenix
I know you didn't want to cut the tab, but I installed the JKS and they're nice and simple. Cutting the tab is more psychological than anything.
JT1
Broken Arrow, OK
2021 Willys Gladiator
Metalcloak has a fairly cheap disco that doesn't require you to cut off that tab..
Jessicuhhh_11
Jessica
Wichita, KS
JLU Sahara
i’m honestly just worried about getting a different lift down the line and needing that bracket
TXSquid78
2024 Willys 4xe; 2005 Corvette
You'll only need it for the disconnects. If you go with a different (ie bigger lift), you can get longer disconnects from jks. I get it, it's a commitment but there are work arounds.
Curiosity question - what shocks did you go with?
Bill_P
Bill
Orange Va
2018 JLU, 2023 JLUWSXR
Can't tell you..shhh
I vote autolynx all day. Yes they are a bit spendy but if you go with a different lift all you have to do is readjust the height on them and go. When I bought mine I went with the 10 inch ones to futureproof a little since I may want to add a little more lift later.
mjf4241
Montgomery, Texas
What if you've already cut off that passenger side sway bar link tab and want to go to something different than JKS? Am I out of luck? Or any other options?
Zandcwhite
Zach
Patterson, ca
2019 jlur
Why Jeep does a single Shear tab on the drivers side and mounts the passenger in double Shear is beyond me. Obviously single Shear is strong enough for the sway bar link, so why worry about it? Even if you cut the passenger side, anybody's links will still mount in single Shear, worst case you might need a shorter than factory bolt.
SoCal JLUS
Inland Empire (Greater Los Angeles)
2021 JLU Sahara 2.0T
I also have the Autolynx. Soooo easy!
