Sway bar links.
Winthrop
Charles
Charlottesville, VA, USA
2023 willys wrangler 2 door
I just purchased a 2.5in rubicon express shocks and springs but it doesn't have sway bar end links. I was wondering if I need to get longer ones for the front and rear or if the stock ones will be fine at that hight.
Bill_P
Bill
Orange Va
2018 JLU, 2023 JLUWSXR
Can't tell you..shhh
I would get longer ones.
Fouts
Marc
Eastern Washington
2023 Rubicon Unlimited
Likely will need longer links. I have seen the rears moved to the front and longer purchased for rear.
XX4XEXX
JD
Ca
2021 Rubicon
Mechanical Engineer
Download an inclinometer app from your I or Android store. Place the phone on its edge on the flatest part of your sway bar aim for 0 to +18° however the sway bar angle should be set with coils removed at full collapsed articulation when you set your bump stops. This will provide correct setting and prevent sway bar flip.
Do not guess and move links front to back to save $$. Do it properly.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
If you're going off road, you'll probably want quick disconnects so you don't have to unbolt them every time.
GATORB8
CLT NC
Any recommendations on ones for a 2.5 lift?
JKS's are pretty popular. You could go crazy and grab the Apex ones.
Bunch of different options, most around $150-200.
No personal experience since we have a Rubi.
TexasRay
Prosper, Texas
2022 JLU Willys XR Gobi - Ordered 5/15...
I recently installed the Apex quick disconnect on my '22 Willys XR - they're very slick and easy to use. As long as you have the needed tools for installation, it shouldn't be more than 1-2 hour job.
Top notch customer support as well.
