Superchips Flashcal Programmer out for JL Wrangler
Mike@Powerteq
Summit Sponsor (Level 3)
Sanford FL
www.superchips.com
16 JK, 21 JL 3.6L M6, 22 Wagoneer 3.0TT
Senior Product Manager – Domestic Tuning at Holley
@Superchips JL, please add the capability to enable proximity to the Flashcal and Trailcal. See this thread.
Interesting. We can look into this. I see in the thread you linked that the other guys are saying it is not doable though, and from the description I see as to why, it makes sense. Worth a look either way.
Thanks
RubenZ
Ruben
Deep South Texas
cyberrube.com
2018 Silverado 2500HD Duramax, 18’ Toyota 4Runner
Does this let you FLASH for the AUX Switches?
Tacoman03
Matthew
Fayetteville, AR
2022 Bronco Raptor 2024 Land Rover Defender 110 2024 Wrangler 392
Man, I have one from last year for my JK, forgot to switch it back to factory using Flashcal when I Traded it in, now I have a Paperwieght Flashcal!!!! It was awesome though......
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
@Tacoman03
Are you sure Superchips does not have an unmarry service.... where you send them the Flashcal and they clear it, so you can use on another vehicle. They do this for a nominal fee.
Will not mention another companies name in this thread, but other's do have such a fee based service.
If you get your unit cleared, you could resell it and recoop some of what you originally spent on it.
kkuntz01
Kevin
Mount Juliet, TN
2018 JLU Rubicon, 2014 Ram 2500 Crew Cab
@Tacoman03
He shouldn't even need to ship it anywhere. He just needs call them up and they can add an "update" (or whatever it is called) to his serial # and then done it's back up and running. Depending on who he talks to and how he explains/approaches it, he could potentially get this done at no cost. I've managed to get this done twice at no cost to me with different FlashPaq's. In one case it was a unit I bought from my buddies brother who had traded his Jeep in and the other the dealer flashed my JK and I lost my tune.
Tacoman03
Matthew
Fayetteville, AR
So just got off phone with Superchip/Flashcal tech guy and here's how it would play out:
$100 reprogramming fee/clearing out old Jeep
$99 gateway bypass module - to convert it to a JL
so alomst $200 to do...not sure that is cost effective!
Oh well,
kkuntz01
Kevin
Mount Juliet, TN
Oh well,
It's not a free lunch, however you're saving $50 over having to buy a new one for your JL so that's kind of a win.
rohdawg
Long Island, New York
Merchant Marine
I have a question and if it’s been addressed, I apologize for asking again.
My Sport S has both the digital and analog speedometer. When I use the Flashcal to calibrate for my new tires, do both speedometers get adjusted? What I’m asking is are they tied together? Is the analog speedometer strictly mechanical like it was in the past (speedo gear swap)?
Thanks! Any info is appreciated.
kkuntz01
Kevin
Mount Juliet, TN
It's not a "true" analog speedo. Everything in the gauge cluster is driven off of electronic signals from the computer. That said, the digital read and the "analog" sweep will read the same.
rohdawg
Merchant Marine
Thank you! I thought that might be so, but I didn’t want to assume that was the case.
Good to know. The programmer arrived yesterday and that’s my project for today.
I appreciate the info.
TJEli
Eli
MI
Jeep, truck, car
My remote start will not work today after using the flashcal. Any ideas why?
-Eli
Bubba33
Saint Louis, MO
18 jeep wrangler Sahara JL
Oh well,
The other one is 50 to unmary, I believe.
TJEli
Eli
MI
Jeep, truck, car
-Eli
I figured it out. If you select the auto start stop disable it also disables your remote start. Just pull the hood pin and don't select the option on the tuner. That sucked this morning. we had snow.
ashg2000
Ash
Atlanta, GA
Jeep Wrangler Rubicon JLU
Speedometer calibration issues
I have Nitto Ridge Grappler 35 x 12.5 x 17 tires on my jeep rubicon JL and used the Flashcal to change the tiresize to 34.75. The speedometer is consistently off by 5%, Jeep shows driving at 42 miles/hr vs. waze or other speedometer tools at 40 miles/hr. Has anyone else faced this problem and found a fix? I will do hit and trial by lowering the tire size, which might help but it's not the right solution.
Swanny297
Swanny297
NELA
2018 JL
Drop it down to 34.5, keep in mind resolution error of the reprogram and Waze/other tools will always show some degree of offset.
