Stereo problem - right channel doesn’t work
Jeffcrna
Mccomb,ms
2021 Jeep Wrangler rubicon eco diesel
My 2021 stereo has a issue. The right channel doesn’t work. Any ideas? Everything is stock
lashlee
Knoxville, TN
'18 JLUR 2.0 Turbo 4 (Sold), Tesla M3P
Considering it's a '21, I would let the dealer deal with it. With that being said, that's awfully strange. Have you verified that someone didn't move the balance/fade to the full left?
TheBirdie72
Rhode Island
2021 Jeep Wrangler Freedom Edition 2 Door
Also maybe check the wiring connections. Something may have shaken loose. ?
Jeffcrna
Mccomb,ms
Balance is properly set. Now the climate control is messing up. Definitely going to dealer.
lashlee
Knoxville, TN
That certainly sounds like a hardware problem with the screen and not a problem with the speakers or wiring...
Jeffcrna
Mccomb,ms
Think it’s the head unit. Climate control is acting up too. Going to take it to the dealer
AFD
Northeastern US
2023 JL Rubicon (2DR/V6)
Not sure which stereo you have, but isn't there some sort of 'reset' for the radio/HVAC that can be done by holding down the power and channel select buttons? Might only be for the uConnect systems, not 100% sure. Disconnecting the battery might also do the same.
Jeffcrna
Mccomb,ms
Tried the reset but didn’t work. Haven’t tried the battery because it’s a pain to disconnect both.
now the climate control is acting up. Going to take it to the dealership
  • Like
Reactions: AFD
Jeepeto
Josh
North Texas
2021 JLUR XR
Sparky
Jeffcrna
Mccomb,ms
I lost both front speakers due to a harness that wasn’t fully clipped in. After taking the head unit out and checking all connections I finally found it on the amplifier located behind the OBD-II port on the drivers side. I’ll try and find the thread where I took some pictures.
Think it might be the head unit. Climate control is messing up now
Jeepeto
Josh
North Texas
2021 JLUR XR
Sparky
Yay ?
Might check the harness on the back of the head unit if you’re a DIY type. I was able to pull mine on the side of the road in Utah trying to track mine down. If I remember it’s just a trim remover and a screwdriver. The plastic bezel comes out and you’ve got 2-3 screws to pull the radio.
God speed at the dealership if it comes to that ?
JeepCares
Auburn Hills, MI
JL
Taking it to the dealership
Sorry to hear about your radio, Jeffcrna
If you need additional support working with the dealer, our team is available via PM if you'd like to discuss further.
Steph
Jeep Cares
Shibadog
Bowling Green, Ky
2020 Wrangler Sport S hardtop
You just have a Mono radio-welcome to 1965…?. Seriously though, sounds like maybe a bad (loose) connection on one side. I’d let the dealer resolve the issue (unless you just want to upgrade to a better unit)
