Steering Stabilizer & Track Bar Contacting
littlem1990
Philadelphia
2021 Willys Wrangler Unlimited
Hello - Recently had a shop install a Yeti adjustable track bar and Fox steering stabilizer 2.0 along with a Mopar 2 inch lift. Have an issue where the track bar seems to be contacting the stabilizers during turns/articulation (see pictures attached). Have searched around and not seeing others with this issue, and this combination of parts seems quite common. Any idea what might be causing?
Jeep Wrangler JL Steering Stabilizer & Track Bar Contacting 20250325_202625
Jeep Wrangler JL Steering Stabilizer & Track Bar Contacting 20250325_202622
Roky
Roky
I’m not sure but probably the pinch bolt , you may consider relocating the stabilizer it will stop this, and be up out of harms way , win win…..
littlem1990
littlem1990
Philadelphia
Hadn't thought of that, thank you! I see that Steersmarts makes a part just for that!
Roky
Roky
littlem1990
littlem1990
Philadelphia
y'all the best, really appreciate the guidance!
littlem1990
littlem1990
Philadelphia
Yeah, you’ll need a tie rod clamp for the other end, if you have the stock tie rod, you’ll need the 1-5/8” clamp……
Synergy sells it as a kit, and it’s cheaper….but there’s a lot of different options…..
https://www.polyperformance.com/syn..._medium=cse&utm_term=SYN-8807-04&gad_source=1
I think I am going to go with your recommendation, realizing that the Smart Steer version does not work with the stock tie rod: https://steersmarts.com/collections...ng-stabilizer-relocation-bracket-axle-side-jk
Roky
Roky
You can also buy the clamp separately, if you like the SS axle side bracket better, (and some people do) then you can buy just the clamp from synergy or whichever brand for the tie rod just about all brackets will work with all clamps….The only brand I suggest buying both axle side bracket and tie rod clamp together is Metal Cloak… they raise the Stabilizer a little so the bolt on their tie rod clamp is slightly angled to match…..
