Steering column
Tinag
Tina
Ga
2020 wrangler jl
Hello,
l need to purchase a steering column for the air bag clock spring. My problem is that part is on back order w/o a delivery date. I found used ones, but the air bag deployed. My question is with the air bag deploying does that damage the wires in any way?
JEEP4U
Richard
2021 Jeep Wrangler
Do you mean to replace the steering colum control module? This module contains the clock spring.
Which part number are you looking for?
Tinag
Tina
Ga
2020 wrangler jl
Yes, l need the clock spring part # 68399807AB
yokramer
Snark Incarnate
Usually if the airbags deploy it will wreck the clock springs. Its possible it doesnt but do you want to take that chance?
jludave
The Isle of Long
IT Manager
Are you sure it is on back order? I enter that part number in Google and get quite a few responses that look like I can directly order from.
I've had success ordering parts from here in the past:
https://www.bamwholesaleparts.com/oem-parts/mopar-steering-column-module-68526258aa
Also, the part number you reference appears to be for RHD vehicles. Are you sure that is even the correct part number for what you need?
This appears to correct:
https://www.moparpartsgiant.com/parts/mopar-module-steering-column~68399807ab.html
Tinag
Tina
Ga
2020 wrangler jl
Thanks, l will try them.
l called mopar parts giant and several dealers with the same response about back order.
