Steel bumper loop?
WrangleDangle
Atlanta, GA
2020 JLUR
I am looking to buy an OEM steel bumper for my 2020 JLUR. I found one but it doesn't have the loop. Is the loop a separate part that I can buy and screw onto the OEM steel bumper or does the loop weld to the bumper as 1 piece?
jludave
The Isle of Long
IT Manager
mrtm1970
Marshall
Orlando, FL
2019 JL Unlimited Rubicon
Mechanical Engineer
The loop is NOT stock to the Steel Bumper. As stated above, there is Mopar available. Also Warn has 3 different heights...I have Mid Hoop:
WARN 102355 Jeep JL OE Rubicon Front Bumper Grille Guard Tube, Low-Height
WARN 102350 Jeep JL OE Rubicon Front Bumper Grille Guard Tube, Mid-Height
WARN 102346 Jeep JL OE Rubicon Front Bumper Stinger Grille Guard Tube, Tall-Height
WrangleDangle
Atlanta, GA
2020 JLUR
Thank you so much for these good links, I'll definately go with one of these instead of the expensive OEM one.
jadmt
jeff
montana
I was looking at the Warn hoop reviews on Amazon and they got pretty poor reviews and surprisingly to me was they are made in Russia.
DonH63
Don
Monument, CO
21 GC Trailhawk, 23 JLU 392 XR
Retired EE; musician (trumpet)
I bought a single hoop from my Jeep dealer. At the time (early 2023) it was about the same price as aftermarket using a MOPAR coupon, and was a simple direct bolt-on to the OEM bumper. There is (or was, have not looked recently) a three-hoop version, but it was not available at that time (though in their accessories catalog). If sticking with the OEM bumper, the OEM hoop is probably the easiest, safest option, and there always seem to be coupons on my dealer's website.
4xFUN
Scottsdale AZ
2024 2-door Ruby-X, 2020 2-door Ruby, 2023 RAM TRX
Grimm mid height, a near perfect match for texture and color to the OEM steel bumper. Made in USA
EDIT: Grimm is a perfect match for OEM color & texture as shown on my JLR-X below!
4xFUN
Scottsdale AZ
OEM is a perfect match if that matters to you.
Sadly the OEM is too short for my taste. That said, if you put the Grimm side by side the OEM, you will be hard pressed to see a difference in color or texture.
jadmt
jeff
montana
Johnny B
PA
2021 JLU Sahara
do you have a close up photo of it mounted? that is a great price.
The bumper isn't installed yet. I did check the bar for any alignment issues. Should be like a 10 minute install with no modification at all.
