Steel bumper
Buckster
Palmetto, FL
'19 billet silver JLUR '16 Grand Cherokee Overland
Power Generation
Looks to be the shell only. Read the description.
spurly
Zach
Nebraska
2019 Bright White JLUR
I still wouldn't get it. I wouldn't put the Mopar rear steel bumper on if someone gave it to me for free. People have reported body damage to the pinch welds after coming down on the corner of the steel bumper. Right now I have the OEM plastic bumper and I'm glad I do. 2 weeks ago in colorado I came off a small ledge and slammed the corner of my bumper on a rock. (There was no other way because you were driving through a cut the width of a Jeep and there's only one line to take) My buddies JK with 3.5 inch lift and 35s even hit his bumper. Destroyed the plastic bumper but I'm certain that if I had the steel, the mount would have crushed the pinch weld.
WalkingJL
Housron
2018 Sport S
That definitely appears to be it, however people with a sport would need the whole kit as this looks to be just the metal bumper which is all the people who are upgrading need.
Robs JL
Robs JL
los Angeles, CA
2018 JL Sahara
Ive got a sahara. would I need all the hardware parts?
S2k Chris
Arlington Heights, IL
AP1 S2000, Rubicon 4xe
Finance
Is there any disadvantage to doing a steel front bumper (for winch, etc) and a plastic rear? I've been thinking of finding a takeoff Rubicon steel front bumper but didn't really have any plans to do the same for the rear.
spurly
Zach
Nebraska
That's the set up I'm currently running. Ordered plastic bumpers and found a front steel take off. I haven't heard of any downfalls with the factory steel front bumper. I guess the only disadvantage to the factory front steel bumper is that you have to buy a winch plate, whereas most aftermarket bumpers already have provisions for a winch. But it's the only bumper that I like the looks of that met my criteria of a recessed winch and fog lights. I wish it had a bit thicker gauge steel but it does the job fine. I'm running my broken plastic rear bumper until my custom ACE Engineering bumper shows up.
shekmark
Manasquan, NJ
Yes
As long as we are talking replacing plastic with steel, does anyone know if our factory plastic bumper Rubi's have a different spring rate than steel bumper Rubi's? I just bought a front steel from a guy and have not put it on yet. Has winch loop, lights etc. Will our front ends be lower with steel? It's around 80lbs.
iznthesky
Edgar
Humble, TX, USA, EARTH, Milky Way Galaxy
2018 Jeep JL Rubicon & 2004 Jeep TJ. Previously owned 1993 Cherokee, 1980 CJ5, & M151A2 while in the Military. For the love of Jeeps !
The steel Rubicon front bumper is only slightly stronger than the plastic standard bumper. Cosmetically it has a better appearance and you can mount a winch in it.....but make NO mistake it is NOT nearly as strong as an aftermarket steel bumper for the JL. I would save the $ $ and buy a good aftermarket steel / aluminum bumper.
grady2hig
Wisconsin
2018 Rubicon JLU, 2017 Toyota Sienna XLE 4WD
Yeah, you lose like a half inch.
