Stage 1 DEF
Gomer Pyle
JD
DFW Texas
2021 Sarge JLUD Willys 3.0 EcoDiesel w/SOT, Cold Weather, Alpine and Tow Pkg
For those of you with a Stage 1 EGR and DEF turned off, what did you do to the existing DEF in the tank? If you drain & replace with distilled water do you run the risk of it freezing? Just curious about the long game when it comes to the DEF being turned off? TIA for any / all insight...
Gomer Pyle
Gomer Pyle
JD
DFW Texas
Remove Tank
thx, that's certainly one way to do it but I'm asking because if/when I sell I'd like to switch it back to stock configuration. I'm wondering if, after draining, introducing a solvent like IPA or similar into the DEF tank along with distilled water would prevent from freezing and not have detrimental effects to the internals / seals / sensors etc? Or maybe a glycol product mixed with distilled water BUT would it present problems to sensors etc? Filling to 1/2 full qith distilled water gives room for expansion but will components freeze/crack? Again, just curious if others have encountered this with deep freeze temps?
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
How about simply putting DEF in it?
Gomer Pyle
Gomer Pyle
JD
DFW Texas
I know, right? I'm not so sure DEF's shelf life and stability to not crystalize etc would make it for 2-3 yrs+? I'm prolly overthinking things...
RicRecon
Ric
NorCal
2021 JLUR 3.0, 2021 JT Overland 3.0
IPAs can be used as a solvent! Now I know why I prefer a good smooth lager or ale.
RicRecon
Ric
NorCal
Yeah I’d be worried about leaving DEF sitting in that tank for that long without it being used. That sounds like a recipe for disaster.
Gomer Pyle
Gomer Pyle
JD
DFW Texas
yeah, just trying to think it thru...thx
