Spot lights ??
rmj339
rod
louisiana
2020 wrangler 2 dr sport s
Has anyone tried or do you know of a pair of spot lights that can replace the factory fog lights in their two slots…….they seem kind of worthless and I am interested in adding some longer range spot beams
thanks
rohdawg
Long Island, New York
Merchant Marine
cosine
NY
2019 Wrangler Sport jl
Gone Postal
@rmj339
baja designs offers the squadron sport r diving lights that will fit nicely in the oem fog light location. they come in driving combo. spot, or wide cornering. they also have ase street legal fogs in clear or ambers.
i have the squadron sport driving combo in amber and they are awesome. i also have the lp4 in spot on the a pillar and driving combo on the bull bar. both in clear lens. they will light up everything. i love their products.
get in touch with @Baja Designs and they will help you out.
dpike
New Jersey
'20 JLUR 3.6
rohdawg
Merchant Marine
Interesting. Any idea how they're wired ? I would almost prefer the high function be able to be wired to an aux switch.
That’s exactly how it works. The mains are plug and play and are controlled by your current fog light switch. The high beam gets wired independently to your aux switch.
jludave
The Isle of Long
IT Manager
KC HiLiTES
Rock Sponsor (Level 1)
Robert B.
Flagstaff, AZ
2020 Jeep JT, 1969 Wagoneer
Lighting Adventures Since 1970
Jeep Wrangler JL Spot lights ?? 1667229156740
There is a harness that would plug in to your factory fog harness, then it also has a split for an auxiliary switch. So you control the fog portion as normal through the factor switch, then the off-road mode would be controlled by a separate auxiliary switch. If the factory fog is off, but you turn on the off-road mode, it will turn everything on. You don't need to turn on two separate switches to have full effect.
https://www.jlwranglerforums.com/fo...-flex-era®-3-dual-mode-sae-fog-lights.103071/
