Splice/utilize 12v rear cab outlet
Brownpow121
Aaron
2021 JLU Altitude Sport V6
Trying to find a tutorial/vid on how to splice into rear 12v hookup to splice into power to install led light strip. I assume it is a constant.
Or thoughts on connecting into dome light. Looking to have better light in rear when hatch is open.
Tarheel.07
Joedy
2020 Jeep Wrangler Sahara Unlimited - Altitude
I installed this light and it works great. The rear outlet can be setup two ways. Default is hot all the time. Or you can move the fuse to get hot only with the ignition power on. I posted pictures of my setup to the site.
https://www.quadratec.com/p/oracle-lighting/led-cargo-light-module-jeep-wrangler-jl-5858-023
Brownpow121
Brownpow121
Aaron
Dagwood
Alabama
2019 Jeep JL, 1999 Jeep xj, 2008 Scion XB, 2015 Scion XB, 1966 Ford F100, 1969 Oldsmobile
CAn you wire it directly? Without having to use the 12v plug?
Yes, just pull panel and tap wires behind. Both 12v plug and cargo light will have two wires, power and ground. Use meter to verify. I would use the cargo light where it would work automatically with door. Led light would draw very little amperage so no problem.
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
@Brownpow121
This thread will give you info in regard to switching that rear 12v to either always on or on with ignition only.
https://www.jlwranglerforums.com/forum/threads/12-volt-or-usb-always-on.8688/
Before working on / if you cut into the wires on that 12v receptacle, do pull the yellow fuse you will find in fuse slot F43 or F45 in the Power Distribution Center (PDC).
After you do your cut splicing.... when you are confident you have the wiring right.... then re-insert that yellow fuse you pulled into fuse slot F43 or F45 dictated by whether you want power to that 12v on all the time or only when the ignition is on.
