High Beam Splice Point
Fred H.
Fred
Chester Springs, PA
2021 Wrangler
I'm looking for a contact on the fuse and relay board for high beams on a 2021 Wrangler, so I can wire some driving lights to come on only with my high beams.
I see helpful dialogue about digging into the front wire harness for a white/grey high beam wire, but isn't there a contact somewhere on the board so I don't have to cut into the harness?
Thanks, Fred
THAW
Foster
23 JL4DrRubicon
Thanks, Fred
The PDC (aka fuse box) doesn't contain a triggered high beam wire because the BCM (Body Control Module) handles headlight switching. The best way to avoid splicing into the factory headlight harness is to purchase a pigtail with factory connectors.
Aussicon
Cape Cod via Australia & N.Z
2021 JL Rubicon Unlimited
Are these actually available?
Terrymo
Terry
2023 JLURXR 3.6 ET
Thanks, Fred
You can use this with a relay, not to wire directly, if I understand correctly
https://www.kchilites.com/wire-harness-adapter-jeep-jl-headlight-6325.html
THAW
Foster
23 JL4DrRubicon
@KC HiLiTES has a version (as mentioned in the above post); it's the best because it also has connectors for fogs, lows, and halos. I use a prototype unit given away on this site for field testing (thanks again KC!).
Stedi UK has one that's often out of stock. There are probably a couple others out there. Another option is to buy the connectors and DIY it.
