SOLVED: High Beam Only On
SmokeyBaer
Baer
Mesa, AZ
2019 Jeep Wrangler Unlimited Sport
I have a new to me 2019 Sport. Pretty well equipped. Purchased used in very good shape. Auto headlamps, LED rear. Still has a limited warranty from the selling dealer, but wanted to run this problem passed the group to see if anyone has come across it in case it's an easy fix.
It seems as though my highbeams are the only working headlamp. When the lights are in the on position (either manual or auto) there is only one brightness in low or high. I assume it is highbeam bc of the power. When I use the MF wand to turn on the highbeams (with the headlights on) there is no change. So it is the same light state in "high beam" as it is in normal "on" position. When the headlights are off and I use the "flash" it does flash, but in the same brightness. Which is why I assume the highbeams are stuck on. These are dual state bulbs, right? Poor explanation, but maybe someone can decipher me.
Busting my cherry on these forums. Can't wait to get to know many of you!
SmokeyBaer
SmokeyBaer
Baer
Mesa, AZ
So I cracked open the housing and took out the bulbs that were installed (used). Saw that they were single beam lights, so I replaced them with some LED dual beams and everything is 5x5 now.
