Spiderwebshade 2 piece
jamief
jamie
Las Vegas, nv
2018 jeep wrangler unlimited sport s
To all of you that would like to order a spiderwebshade 2 piece... be aware that it has to be reconfigured for dual tops and changed depending which top you are using
RedLine
Keith
2020 Rubicon (replaced 2018 Cherokee Trailhawk), 2013 JK Sport (Bought for Daughter)
I'm considering the two-piece, can you explain more what you mean about "reconfigured"?
TIA.
jamief
jamie
Las Vegas, nv
the front straps of the back piece have to come off and go to different spots to hook up. sometime thru the roll bar and other times in between the soft top rails. get the 1 piece and save yourself a headache. the whole thing also flaps alot.
RedLine
Keith
Ok, thanks for the feedback, I will investigate further.
Mom2SNSH
Wendy
VA
Jeep Wrangler JL Sahara
Yeah, I just tried to put mine on yesterday. The front part went on fine, the rear is being an absolute BITCH.
jamief
jamie
Las Vegas, nv
ya. I couldn't stand it. I returned it. stick with the 1 piece if anything
Yellowssm
Ray
Las vegas
JLUR
Installed my 2 piece version sunday without taking the hard top off. I’m am not mechanically inclined at all and it was pretty easy imo. Also had my buddy cerakote the little nubs red to match the other red parts inside
Jeep Wrangler JL Spiderwebshade 2 piece D4EB7EF0-8BAA-4F6B-8376-8054976F3F61
Jeep Wrangler JL Spiderwebshade 2 piece 2C0A4270-38A0-4B7B-B92B-8699B43EB741
kosinar
South Carolina
2020 Black JLUR 3.0 EcoDiesel received 3/6/20
Would this work with best top sunrider?
Jammer
Ft worth
Bright white JL Rubicon
That looks good how it is close to the windshield. is it touching in the middle and about a 1 inch on the ends here's my Alien 2 peice it has a 2 inch big gap in the front and there's nothing i can do to fix it. You have to admit this looks bad that's to much sun that comes through not to mention how bad it looks
Jeep Wrangler JL Spiderwebshade 2 piece Screenshot_20200508-173102_Gallery
Jammer
Ft worth
the front straps of the back piece have to come off and go to different spots to hook up. sometime thru the roll bar and other times in between the soft top rails. get the 1 piece and save yourself a headache. the whole thing also flaps a lot.
You mean like this ? i know i want to get the 2 piece i don't want the one peice because it has the big hump over the sound bar. i like the clean look on the 2 piece on my alien but its has to much of 2 inch big gap in the front but doesn't the spider web shade still have a about a 2 inch gap up front by the wind shield like the alien does ? because i did see a 1 and 2 piece spider shade and they both still have big gaps up front. i guess only way to stop that big gp is with Jtop with theres flips into the front real close and folds back to reach the handles when needed. But this 2 piece looks terrible like yall said on the way it installs in the rear front. did anyone get this and have no problems with the way it looks ?
Jeep Wrangler JL Spiderwebshade 2 piece spider rear shad
Jammer
Ft worth
How did you put the 2 piece on with the hardtop on ? did you have to put those 2 bungees in the hole on top of the rear roof ? it looks hard to feed the bungee in that little hole. isn't it hard to do this ? THIS LOOKS HARD TO DO THIS PART ON THE REAR SHADE WASN'T IT ?
