Gangplank
- Sep 15, 2019
- Vero Beach, FL
- 2021 JLU Willys 3.6 eTorque w/ Mopar lift. 2022 JLU Rubicon 2.0T still stock
- Build Thread
- Link
Update - There is so much info on the forum but most of it mixes up the base 5”/7” & upgraded Alpine versions that it is confusing to research. This post is about the 7” base non-Alpine.
I also decided to go with 6.5" speakers in the JLJT pods instead of 6x9's to avoid having to cut into the soundbar. I
--Updated plan after a LOT of research--
Jeep JL - Audio Upgrade
2021 4‑door, hardtop w/ 7″ base OEM head unit (non-Alpine)
Stage 1 — Front Dash Speakers
Stage 2 — Soundbar Upgrade to 6.5”
After adding the Audio Uprising front dash speakers they are great for sound stage. I am very impressed! - the component system and high impedance results in great sound and MUCH better clarity, sound, clear range and good mid-bass, from the front. You can HEAR the music & sounds that were muddy before stand out now. Highly recommend them. Note: they take a good few hours/days to break in and then the sound comes alive.
They sound great turned up in the 18 - 25+ range. I originally put the polyfill in but didn’t stuff it down enough so I went back and stuffed it down the the crevices of the dash and WOW THESE SOUND GREAT
update 2 -
I installed the 6.5” Morel Maximo Ultra. I also added some hushmat sound deadening behind the speaker magnet and stuffed polyfill in the crevices of the soundbar.
The sound Is so much improved over stock! I’d say the Audio Uprising are a solid 50% improvement in sound quality and now + the Morels is another 30% improvement again. The sound is clear and the mid-bass and bass is much improved.
Now my dilemma is do I need the Alpine Sub or call it good enough??
First world problems… I know…
✓ Audio Uprising Upper Dash Component Speakers (DONE) $250
- 6.5” Morel Maximo Ultra Coax 602 MKII $210
- Using JLJT pods $150 (so I don’t have to cut up the soundbar)
- Hertz 201F powered under seat sub $350
- Audiotec Fischer Match Up 6DSP $700 - $800
- PAC AmpPro AP4-CH41 ($?)
- After installing the Audio Uprising and Morel Maximo I am leaving the OEM knee speakers in place.
update 2 -
