Spark Plug replacement
Tim_JLU
Tim
2019 JLU Sahara
So I changed the plugs on my 2019 Sunday. Pretty easy and straightforward. But dang it.
On a cold start I get a slight backfire sound pop pop, only at high idle and goes away after a couple of seconds.
Jeep runs great, no codes, no misses and I am getting 24+ MPG.
Coil pack not all the way seated?
Thoughts?
chevymitchell
Shawn
Pueblo West, CO
Avi Engineer
Thoughts?
What part # plugs did you use and what were they gapped to?
Tim_JLU
Tim_JLU
Tim
2019 JLU Sahara
NGK 92019 .26 was the gap same as the ones that I replaced.
Like I said this is only on a cold start up at high idle. Runs great other than than.
Maybe I knocked something loose?
I did not even have to unplug the coil packs on cyl no 3 and 4.
I am free tomorrow going to take a better look at it.
Manuel76
Manuel
Spain
Wrangler Sahara JLU 2.0 2021
Yesterday I changed the spark plugs on mine and had the same problem in cylinder number 1. It turned out to be the distance at the tip of the electrode, which I must have hit it by accident or it came like that. I put the correct gap and the problem is over. My advice is to check the gap on all 4 spark plugs.
