Spare Tire bump stops
Aquastream
Andrew
Alberta
2021 JLR, Hella Yella, 2.0 T
Hey guys.
I just added the mopar slotted wheels to my rubicon, the offset is +12 and tires are 12.5 wide but even though still it isn’t touching the bumps .
There is about <1/2 inch or less in between so i’m looking for diy ideas to get something in there to support the spare from bouncing up and down!
The squash ball idea is great but there is not enough room in there to fit it!
Thanks for any replies !
Andrew
2nd 392
Ca
Cheap way use pcv pipe, or get a Teraflex spacer kit that comes with different size spacers.( came with my relocation brackets) There are also cut to size available.
ellunchboxo
Baton Rouge, La
2024 Anvil Willys 2 Door
PetroChemicals
Hey guys.
Andrew
Amazon has a few extended bump stop options for about $25. Cut to fit.
ParadigmDawg
Greg
Fort Worth TX
I used rubber step down plumbing couplers. They slide ride over the stock bumps and you can cut the length to what ever you need. The fit was tight enough that you don't need the clamps.
Jeep Wrangler JL Spare Tire bump stops Screenshot_20240318_084454_Chrom
RicRecon
Ric
NorCal
2021 JLUR 3.0, 2021 JT Overland 3.0
This. picked up at nearest local big hardware store and spare does move at all.
Aquastream
Aquastream
Andrew
Alberta
All the options are great but i love this one!
If i can avoid having to totally replace the current bumps that’s best, because they are a b*^!h
Aquastream
Aquastream
Andrew
Alberta
Given that i’ve only got about 1/4-1/3 inch of space i think the only option right now where i can add to my current bump is the plumbing fittings, I’ll report back!
Thanks everyone!
Aquastream
Aquastream
Andrew
Alberta
Was this the size that you needed??
I left home to the hardware store and i haven’t measured the bumps
Aquastream
Aquastream
Andrew
Alberta
Thanks for this tip. They slipped right over the factory bumps and i trimmed them to the length i needed. It works great and was below $15 in canada.
Jeep Wrangler JL Spare Tire bump stops IMG_0501
Jeep Wrangler JL Spare Tire bump stops IMG_0500
Jeep Wrangler JL Spare Tire bump stops IMG_0502
Jeep Wrangler JL Spare Tire bump stops IMG_0506
