Sky one touch high frequency noise
Jjirish
Jenne
2021 Jeep 392, 2024 Jeep 392, 2023 BMW X7C
Lurking the forum
Does it do it while you are keeping the steering wheel perfectly straight and still?
Whiskey313
2021 Jeep Wrangler
This may be the issue especially since the OP said the sound goes away when the windshield is wet.
I have not replaced windshield yet as crack has happened in th
I notice mostly during freeway driving. Not a whole lot of turning on freeways. It usually happens between 55-80mph.
Jjirish
Jenne
Lurking the forum
@Whiskey313. When I watched your video I heard the sound when you were slightly steering to the right.
But with such a short clip it was hard to tell.
jimmym1981
Chicago
Have you had someone ride with you and move around to pinpoint where the sound is coming from? Might be worth a try.
Wbino
NJ
This fixes a lot of unknown noise issues:
Whiskey313
2021 Jeep Wrangler
Yes, I’ve ridden with dealership technicians, service manager, service writer as well as a body shop manager. And no one can pinpoint where it’s coming from. We are all at a loss.
BW20
Bill
Bradenton, FL
2022 JLU Rubicon, 2014 JK Sport
Compliance Officer
I still suggest replacing the windshield. You’re going to have to at some point anyways. The noise could be a bad seal between the glass and the body. This happened on one of my trucks years ago. Sounded very similar to your video. Can’t hurt to try since you will have to do it anyways.
jimmym1981
Chicago
That is really odd. I wonder if its something with the trim around the windshield. The oddity is it stops with water on the windshield. That is really odd. Either way, it would drive me NUTS as well. Does it happen if you barely crack open the SOT?
Wbino
NJ
Have you driven with the
1. Windshield down?
2. SOT open all the way vs closed?
3. Check for something stupid like glovebox stuff rattle?
Whiskey313
2021 Jeep Wrangler
1. Windshield down?
1. never been driven with windshield down - per manual not supposed to lower windshield on sot, however dealership did lower to reseal frame to hopefully fix noise but it didn’t.
2. Does not make /or hear sound sound with sot open
3. Glove box is empty
Deleted member 72291
Guest
I have a buddy that had a very similar noise with his soft top JL, and he finally traced it to a pinched wire causing a short in one of the speakers. Even with the radio off, the speakers are still getting power.
RAMSTEEL
Rick
Virginia
2023 392 XR
Army (Ret), Fed Guy
Put painter's tape around the outside of the windshield and drive it again. If it goes away, there's a seal issue. You can remove sections at a time to attempt to discover where it's occurring.
Partybriz
Lbw
Van Alstyne Tx
2024 Jeep Wrangler Sport S JL
I have a 2021 Jeep Wrangler sport with the sky one touch. Jeep has high pitched sound coming from somewhere. Top, windshield, doors, even back seat has been readjusted/lubricated/resealed and nothing has solved the issue. This noise is a migraine trigger for me. I’ve had the Jeep for less than a year. And it’s been in the shop 4 times trying to find/fix this one issue. Has anyone else had this problem found a fix? I don’t know of any other way to explain it other than either sos signals or Morse code in high pitch sounds
( video of sound-while driving. Only way to prove what I’m hearing
Did you ever figure this out Just bought 2024 JL and it has this EXACT sound when I drive at highway speeds 70-80mph
