Side Steps / Running Board Recommendations
CurlsNAJeep
Chimere
IL
2024 Jeep Wrangler Sport S
Hey Y'all! I just recently purchased a 2024 Jeep Wrangler Sport S about a week ago! I absolutely love it! This is my first Jeep! I'm looking for recommendations on side steps/running boards. If anyone has any recommendations, pros and cons of each, what not to do or learnings to share, I'm all ears!
Thank you!
STW
Utah
2022 JLR 2door 2.0T Rubicon stingrey
It will depend on if you want 1) actual step-up help to get into the Jeep, which is sometimes helpful for shorter people getting into lifted Jeeps. Or 2) something that looks good there and covers up the pinch seam the Sport model leaves exposed.
If you just want #2 then I recommend finding some Rubicon take-off Rock Rails. They look good, cover that pinch seam, give some decent slider protection for what they are, and lots of people replace them with heavy duty sliders so you'll find take-offs to buy. But they don't have a step and are not a running board.
Since you asked about running boards and steps, I'm guessing you're not looking for sliders or rocker protection, which is what you're most likely to see on most built Jeeps and are intended to protect the lower side edges of a Wrangler from rocks you can bounce on or scrape on in off-road situations.
My experience has been that to get actual help stepping up into a Jeep for someone who needs it, you need a step lower than the edge of the Jeep. You need something the divides that step-up height in to two steps. Proper sliders are too high to help that even if they have a step built in. You probably know this, but sliders are they're designed that way to stay high and out of the way of rocks so they don't reduce your off-road clearance.
Meanwhile any running board with a useful permanent step, has that step dropped low enough to severely reduce rocker clearance and will get torn off if you do any rock crawling.
There are a few side steps that retract up so they stay out of the way and don't reduce clearance, but other than those, you're choosing either slider protection with good clearance or a useful step-up but not both.
Dusty Dude
Colorado Springs, CO
1970 Ply Roadrunner, 2010 Challenger SRT
Congrats! It will somewhat depend on how you plan to use your Jeep. Rockcrawling will require a totally different set compared to mostly on road use. Gravel roads can make a difference too due to rocks being picked up by the tires.
CurlsNAJeep
CurlsNAJeep
Chimere
IL
THANK YOU SO MUCH! I think for now I'll go option 2. I'll definitely take a look around!
CurlsNAJeep
CurlsNAJeep
Chimere
IL
It'll probably be just Road use for now. Not quite ready for off-roading just yet! :)
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
As others have said, it depends on what you're wanting them for.
We do more challenging trails and my wife wanted something that would help her deal with the height of 37s / 3" lift. Not cheap and not quite as durable as some without the step, but they're pretty awesome. Definitely not cheap.
https://rockslideengineering.com/product-tag/jl-step-slider/
DonBindas
Don
Naples, Florida
Ordered a 2020 JL Rubicon Unlimited in Bikini with Dark Saddle Leather on 7-8-19 and was delivered by Criswell 8-22-19
KBB Analyst
Jeep 2024
Bob Bitchen
calif
2024 JL Rubicon - 1990 YJ
I just installed a set of Amp Research electric steps this week end on my 2024 Rubicon.. Sweet set up if ya got 2K to spare.. Install is easy 3 hr project if your handy..
JJ_WA
JJ
Puget Sound, WA state
2002 Dakota, 2017 Cherokee, 2023 Willys XR
Retired US Army, Higher Education
I found a set of Running Boards for the Sahara on eBay to be just what we need for that extra boost into our Willys XR. Our use case is light off-roading, primarily road driving. I paid about $150 (less than what take-offs were being asked for around here) and really like them:
Running Boards for 2018-2024 Jeep Wrangler JL 4 Door 6" ABS Nerf Bars Side Steps
https://www.ebay.com/itm/193130470227
They came complete with all the hardware needed to mount.
You can check out the first post in my build journal to see how it went: https://www.jlwranglerforums.com/forum/threads/jj_wa-willys-xr-build.114395
tker32
Tyler
Iowa
2021 Wrangler Unlimited Sport S
me109stock
Martin
Linden, CA
2018 JLU Rubicon 6-Speed Manual; 2008 Ford F450; 2003 Porsche Boxster S
My first mod was Rockslide Engineering steps. My wife needed them to assist her getting into the jeep even stock, so I knew lifted she would absolutely need them. The RSE steps extend about 10" when deployed - I can get measurements from ground level on my 3.5" Metal Cloak lifted on 37s jeep if you want me to. I also knew I was going to be banging them on rocks - and I can tell you they live up to the hype. I don't have the additional 1/4" armor installed on them and I can tell you from experience they can handle at least a 6" drop onto a rock and pivoting the jeep around boulders on the slider. Mine have more than a few scrapes from trail running... in my opinion they are the best option if you want a high step and rock protection. Like mentioned in a prior response, they aren't cheap, but they are worth every penny if you need a step and rocker protection.
Annie oakley
Annie
Georgia
2020 jeep wrangler willys
Thank you!
