Service start/stop, gear indicator, reverse camera not working after regear
Jeremynolan94
Jeremy
Vista, CA
2022 Wrangler Willys Sport 6-spd, 4.56 gears, rear Trutrac, front Torq locker
Hi all,
Last week I had my 2022 Willys Sport 6-speed regeared to 4.56 and installed a front Torq locker and rear Trutrac. I used Jscan to reporogram the computer for the new gear ratio.
Immediately afterwards my service start/stop light came on, and my gear indicator and rear view camera stopped working. I had the gear position sensor recall (92a) completed today with the hopes that doing so would fix this issue, but it is still going on. The gear indicator, reverse camera, and start/stop system all work at first, but after only a minute or so of driving become inoperable. Any ideas how to remedy this issue? I'm going to permanently disable the start/stop system but would obviously like to continue to have my gear indicator and rear view camera.
I tried doing the 6th gear relearn procedure where you drive at 70mph in 6th for 30 seconds, but unfortunately the light has been coming on before I even make it to the freeway.
Jeremynolan94
Jeremynolan94
Jeremy
Vista, CA
Update: turns out I wasn't doing the 6th gear relearn procedure correctly. I was disconnecting the negative battery terminal but failed to disconnect the aux battery from the main while I was at it. I disconnected everything, let it sit for several minutes, reconnected, and did the relearn procedure. So far, so good.
