Service Shifter - Power Steering
VentTekk
NH
2018 JLUR Stock, 2017 GCTH Stock
Live Operations Engineer
Anyone have any updates on their service shifter issues? Mine was out of the shop for 9 days before the service shifter came back after they determined that the sway bar disconnect was the issue.
I am not the original poster, but I do have the same/similar issue.
I have an active case with Jeep Cares, and although the situation has not been ideal, both Jeep Cares and my dealership have been helpful and continue to be attentive.
My Jeep has been in the shop for 25 days. The dealer technicians have pages of error codes, and about 50-ish pages of diagnostics they have attempted with Jeep Engineering. They have put about 1200 miles on my Jeep during its stay at the dealership, and as it stands, it cannot go 100 miles without throwing codes or shutting down.
Here is a rough timeline of events and facts.
  • I drive a lot, 100 Miles a day (to/from work).
  • JLUR Jeep Build Date October 2018, Engine is the 2.0L.
  • Purchased Jeep 01/21/2019
  • 1000-3000: Miles, no real problems only steering issues at highway speeds. Self-adjusted tire PSI to 36 from 45, which made it manageable.
  • 3000 Miles: reported loose/wondering and dead spot in steering, requested that all steering components be checked. No issues were found.
  • 3000-6000 Miles: minor electrical problems, backup camera would stop working or get stuck on, or would randomly move through the menus on its own. Passenger side seat started creaking/popping with someone in it (I temporally fixed this with some grease). Steering is getting worse at highway speeds.
  • 6000 Miles: Had an oil change performed and reported loose/wondering and dead spot in steering. Oil was changed, and the stabilizer was replaced with the 2nd revision. This greatly improved the dead sport and wondering. I also test drove another 2018 JLUR that had zero issues with the steering.
  • 7000-9500 Miles: discovered rust bubbling on the door hinges. The radio and backup camera continue to be flaky, and I still have not fixed the passenger seat. I figured I'd just lump all these issues into my next visit since they were relatively minor.
  • 9500-10000 Miles: No new issues
  • 7/10/2019 - 10000 Miles: Left home for work, made a quick stop to drop my dog off at daycare, came back to the Jeep and it would not start or go into accessory mode.
    • Checked the fuse box and found about half the fuses not seated correctly. Push all fuses back down, still won’t start. Pulled the Stop/Start and Starter fuses, electrical systems came back on and I was able to go into accessory mode. Reseated Stop/Start and Starter fuses and the Jeep started right up when placed into run mode.
    • Drove to work 50-miles away, entered the parking garage and every time I hit a speed bump, the service shifter indicator would come on.
    • Parked the Jeep and figured it wouldn’t start again. Called my dealer to make an appointment (They cannot get me in until the following week). Came out of work and the Jeep started right up and drove home with no drama.
  • 7/11/2019 - The Next day, I drove to my coworker’s house to carpool. No drama on the way to my coworker’s house. Placed the Jeep in park and idled in the driveway while waiting. Coworker gets in, I place the Jeep in reverse and then it malfunctioned just like in the video. It did this in both drive and reverse and after multiple restarts. The Jeep gets towed to the dealer.
  • 7/12/2019 – Dealer pulls about 3 pages worth of codes, they immediately start a star case. Jeep Engineering requests that all codes be reset, and that they drive it until the codes pop again. This took about 3 days’ and about 300 miles worth of testing, but the situation did resurface.
  • 7/12/2019 – 8/2/2019 Details from this point forward are not well known since they still have my Jeep. I do know that faulty connectors were found in the front passenger wheel well, as well as a bad ground that was covered in glue. Likely other items were replaced/checked since they have about 50 pages, 20+ hours’, and 1200 miles worth of troubleshooting and diagnostics.
  • 8/2/2019 – I requested that Jeep Cares escalates my case since we are both losing money at this point and I miss my Jeep.
At this point one of two things are going to happen.
1. Lemon law will be pursued since my Jeep has been in the shop for nearly 30 days (currently 25 as of 8/4/2019) with no end in sight. Also, this is the 3rd visit for steering related issues. The safety and reliability of this 2018 Jeep are seriously compromised, and I refuse to take it back.
2. Jeep makes it right. Jeep needs to take this unit back to the factory and tear it down, so others do not go through this. I need to be compensated for my vehicle and time.
canuk688
Carl
Golden, Colorado
2018 Jeep Wrangler Rubicon (White)
Mine is still in the shop, today is day 26. Heard that Service shifter module didn't fix the issue and they are giving me an update 8/6 on what they are going to try next. Still seems intermittent without really being able to pinpoint what the cause is.
Willcbooth
Will
Fort Worth, TX
2018 JLUR 2015 Lexus GS350 FSport
Mine will be going back to the shop Friday. Today was the second time Service Shifter has come back after less than 2 weeks out. It spent 35 days in the shop the first time. Today I was backing out of the driveway going less than 5mph and it came on. Sway bar disconnect is obviously not the issue.
VentTekk
NH
Mine is still in the shop 31 days without a fix. All Wiring has been checked, and they have now moved on to the selectively replacing modules. The Jeep is still throwing codes like mad (80+) and shutting down randomly on their test drives. I keep calling Jeep Cares and Chrysler Customer Care and pushing for a replacement. At this point we are both losing money, and the situation has become ridiculous for all parties. Jeep should takeback the 3-4 Jeeps mentioned in this thread and do a complete teardown.
Willcbooth
Will
Fort Worth, TX
Mine went back to the shop today. On my way out there, service shifter came on while coasting at 25mph. It came on 2 days ago while backing out of the driveway. Very random times.
cool_it
Bob
Whitehall, PA 18052
www.ballardphotos.com
2018 JL Unlimited Rubicon; 2008 Liberty
Fire Protection / Mechanical Engineer
As an update to the forum, my JLUR had the following parts replaced, P/N 68251037-AC and the issue appeared to continue and they next replaced the sway bar disconnect wire harness, P/N 68351030-AE and thus far no issues. The only side effect I have seen so far is that I no longer am able to use the Uconnect App and gather data nor do I receive the automated Health Reports.
Jeep Wrangler JL Service Shifter - Power Steering {filename}
VentTekk
NH
Quick update, my Jeep is still in the shop. The Body Control Module (BCM) has been replaced and they have test driven 40 miles without throwing any codes. The dealer is going to continue testing over the next few days, so I will update if anything happens. I am still working with Jeep and FCA to get this issue resolved in a meaningful and fair manner, but as mentioned before its getting ridiculous.
UK_Jeepey
UK_Jeepey
Luke
Leeds
Jeep Wrangler Overland
UPDATE: JEEP IS FIXED!!
Head engineer flew out and looked at it. The problem was a faulty wire with the cooling system. This in-turn affected the Cam system which caused the electrics to mess up.
They replaced the wire and 300 miles later, no issues.
VentTekk
NH
That is great news! I am still waiting on mine. I'll be interested if the BCM fixes my issue.
YarrrMatey
Ken
Houston
2019 Wrangler Rubicon
@VentTekk - any update?
My JLUR 2.0L went on the fritz this morning for the first time and noticed the Service Shifter message pop up. I've reseated the fuses and the CEL went away. I no longer have any warning lights since the reseat of all the fuses, just the intermittent Service Shifter message.
I'm not liking the thread on this issue as my JLUR has already been in the shop for 3 weeks in August to replace the TCM.
JeepCares
Auburn Hills, MI
JL
Hi Ken,
We're sorry to learn that you have experienced this. If this continues to happen and you decide to visit your dealer, please keep us updated. If needed, we are available via PM to connect you with a Case Specialist.
Alex
Jeep Cares
YarrrMatey
Ken
Houston
@JeepCares - Thanks, I was at my dealership this afternoon for service and talked to my sales rep as well as the general manager. When I told them about the fuses not being seated, they didnt believe me, so we popped the hood open on 2 showroom 2020 vehicles, Sahara and a Gladiator Rubicon, the fuses on both of them were not seated properly.
I drove around 100 miles today and did not have the “service shifter”, so we’ll see.
JeepCares
Auburn Hills, MI
JL
Hi Ken,
Thank you for the update! I hope this remedies your concern permanently.
Alex
Jeep Cares
YarrrMatey
Ken
Houston
@JeepCares I spoke too soon, all of my warning lights went off again while at a stop light, was able to get the JLUR started but it would not shift. Pulled into a gas station, and let it sit for a few, started up and dropped it off at the dealership.
JeepCares
Auburn Hills, MI
JL
Hi Ken,
We're sorry to hear that this has returned. If you need any assistance while at the dealer, please send us a private message.
Alex
JeepCares
