Maverick909
- Brian
- Jan 15, 2019
- I.E.
- Website
- www.instagram.com
- 2018 JLU Sporticon, 1976 GMC K15, 67 Notchback Barracuda, Indian FTR
- Build Thread
- Link
- Occupation
- Electrician/ Industrial Furnace MFG
nothing is perfect, Its just a deterrent to cause the would be thief more grief. They don't like when things take to long. Plus if they computer swap the fuse is a better option. BUUUTT, it only takes a second to open the fuse box and see if someone added one of these in line terminals things to the starter Again nothing is perfect but anything helps.if you’re going to pull something, why not pull a fuse or relay to the fuel pump? this would surely answer your question in the negative.
another thought - if they can pick the lock to the door, why couldn’t they pick the lock to the hood?
another thought - couldn’t they just pull the cord in the console to put it in neutral and wheel it away?
ugh. sorry for the depressing post!!
to the OP here is the starter circuit. fuse F02 40A Stater system fuse- F04 25A fuel pump relay fuse
https://www.jlwranglerforums.com/JL...S_RELAY---MISCELLANEOUS---2.0L_3.6L---ESS.pdf
