Rubicon Height
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
285/70R17 is stock size but BFG KO2s. Different tires from different brands (or even same size within brand but different model) will measure differently.
Also if your tire pressures are lower it will sit lower.
Those Falken Wildpeak MTs in 285/70R17 were optional on the Rubicons.
  • Like
Reactions: LCW
jaymz
Jay
Inland Empire
2018 Rubicon Unlimited
Is that picture and measurement of yours AFTER level? What size did you use?
Front and Rear
No. That measurement is with all of the factory suspension and tires.
jaymz
Jay
Inland Empire
Yeah steel bumper and winch. Winch will be removed though. Think winch makes an inch difference though?
Steel bumper and a winch will definitely make a difference. Even more so if it came with plastic bumpers to begin with. Of what I’ve heard is true, the factory springs are slightly different depending on the bumpers that were installed on the assembly line.
Brock9281
Brock9281
Robbie
Alpharetta GA
2021 Rubicon Unlimited
Came with steel bumper. Winch was added. Should I expect to see some extra height once winch is removed?
Do the JLUR have leafs that can be added in front or back?
GATORB8
CLT NC
Wire rope winch can get close to 100 lbs, call it an extra 50 for the steel bumper. That’s a small person hanging off the front.
Brock9281
Brock9281
Robbie
Alpharetta GA
You're adding a lift and larger tires anyway. Stop obsessing over an inch and get to work! :LOL:
I know right?! Just want to be sure that going with the 1.5” vs 2” is better…half an inch ?
GATORB8
CLT NC
Yes, but why remove it?
JLs are coils all four corners.
GATORB8
CLT NC
The TF 1.5” spacer is 2” front, 1.5” rear.
rcadden
Ricky
Asheville, NC
Marketing
Came to *you* with the steel bumper, but you said you bought it used - you need to know if it came *from the factory* with plastic or steel bumpers.
Wranglers come from the factory with different springs based on their original factory equipment. If it came with plastic bumpers from the factory, it will have shorter springs than if it came from the factory with steel bumpers.
