Rubicon front camera
DieselDan
Kelly
Terra Ceia Florida
2022 Jeep Wrangler Rubicon Unlimited 4cyl turbo
I have a 2022 Rubicon. Is it possible to add a front camera to the Alpine system?
Kracka
Christopher
Oak Point, TX
C8 Corvette, 19 KL Trailhawk Elite, 23 JL Rubicon
I believe a Tazer let's you do it all.
redracer
Robert
Manteca, CA
2023 4xe Rubicon
Possible, yes i believe...
But to do it factory style, with crisp HD quality, there is an additional module that connects between the uconnect head and the rear camera, then also connects to the front camera and power and canbus. I don't know if anyone has listed out all the wiring harnesses that you'll need. Then there is the programming, I think JScan can enable/disable the feature but I don't know if it will "Just work" or if the new module will need programming too.
As far as the Tazer solution.... that is much easier, but also lower quality as it enables and uses the analog Standard Def. input that was intended for a truck bed camera for the ram series trucks.
Terrymo
Terry
2023 JLURXR 3.6 ET
DieselDan
DieselDan
Kelly
Terra Ceia Florida
Thanks this is what I was expecting. Complicated and spendy. Se la vi!
