RockTrix RT105 17
LukeDagny
Central PA
2021 JLUR
Here are some more pictures of Jeep Wranglers on our Rocktrix RT105's~
For those of us that live in an area where it's illegal to run the tire past the fender flairs, does Rocktrix have any plans to make any wheels with more positive offset, say in the +30 to +45 range?
RockTrixWheels
Rock Sponsor (Level 1)
Chino, CA
2023 JLUR 4xe, 2018 JKR
Ooh I like them.
Thank you! Let us know if you have any questions regarding them~
Unfortunately we don't have any immediate plans but we're constantly making new offerings and we'll take this feedback under advisement. Thank you so much for your inquiry!~
dlong1119
Gainesville, FL
21 Sahara 4xe (StingGray)
Just run the +12 wheel and install a set of Mopar (or Amazon) XR fender flare extensions and call it done!
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
Trix are for kids.
Cips
Anthony
Bucks County PA
2021 Wrangler Unlimited Willys
Sales
These are hub centric, correct?
Blues Fan 30
St. Louis
I would think the +12 offset with some xr fender flares would keep you legal no?
LukeDagny
Central PA
2021 JLUR
+12 offset moves the wheels out 1.4", XR flares add 1" at most, and I'm going to a wider tire. It will be close.
Blues Fan 30
St. Louis
It moves the wheel out, but the wheel sits in at +44 to begin with so it's not pushing 1.4 past the edge. My kmc are +10 for reference with the toyo at3 wheels. Had to dig back but found the photo I took when I first installed them to show how they sit.
Jeep Wrangler JL RockTrix RT105 17 20240129_104405
LukeDagny
Central PA
2021 JLUR
I would love to have some Rocktrix, but I'm very close to the edge now, and PA has some weird inspection laws.
I'm using the Wheel Offset Calculator, comparing my OEM set up with +44 offset wheels to a narrow set of 35" tires on +12 offset. The wheels move 1.4"
I might be OK with a set of XR flares added, but I want to be sure in my mind before I spend the money. I think a set of RT113's in matt bronze would look great on my black Jeep. The only other bronze wheels I've found close to OEM offset are much more expensive.
https://tiresize.com/wheel-offset-calculator/
RockTrixWheels
Chino, CA
Correct yes these are hub centric
You should be okay especially with the XR flares with the +12's they shouldn't stick out far from the flares. Here's another thread with a similar setup:
https://www.jlwranglerforums.com/fo...-wheel-fitment-on-a-sport-with-315-70s.57083/
Blues Fan 30
St. Louis
I guess the real question is how big of sticklers are they? I feel like you should be completely covered by xr flares but let's say hypothetically they stick out past by a hair will they really say anything if it's not immediately noticeable?
I will also say that if you want to stay hub centric I don't think there are many options with more than a +12 offset outside of the stock wheels. I researched all over for hub centric choices when buying mine and can't recall finding anything with a higher than +12 number. The +12 is probably your best choice.
