Rock Krawler 3.5 X-Factor
Rock Krawler Suspension
Tech Support
Waterford New York
rockkrawler.com
Red JLUR, White JLUR, Yellow JL (3 so far), Bikini Diesel JLU, Billet JT, Hydro Blue JT
It is all good. Enjoy your rig. Not sure how you or where you are measuring the difference but component for component RK offers more and it is simple math so there is no opinions required. MC components out do our Adventure Series Lowers by a little bit. For example, 60 degrees of misalignment out of the RK Adventure Series Lowers versus 68 out of the lowers for MC - but the RK X Factor has a total of 90 degrees of misalignment...
19JL
Bobby
Bend Oregon
2019 Jeep JLUR
We understand completely.
An 850 on 37's is a respectable score. We personally like the 3.5" with 37's on Rubi's if you are not removing the inner fenders. Our "Maximizing" the 3.5" on the Rubi comes with 38's and full fenders or removed inner fenders and 40's. We really feel the new Dana 44's will hold up well to 38's. 40's - well that will be debatable, but they did do well for all the rigs in Moab that had them.
There is still a lot to learn on the JL and JLU and we are very confident that aftermarket will start filling in the holes....
Good luck with your continued effort the maximize the potential of your JLUR...
RK
How are you guys still feeling about this statement. I’m on the fence between 37s and 40s on factory rubi axles regreared. I need to run it that way 6-12 months.
Tech Support
Waterford New York
rockkrawler.com
40's are pushing the stock 44 axles, but a sensible wheeler with 37's or 38x13.5 tires will do very well on the stock axles. Regearing will be a great option to look at in the future for sure....
RK
Mojitojlu
New york
2018 Jeep Wrangler Jlu rubicon 2017 Jeep Wrangler jku. 2003 Jeep Wrangler Tj rubicon. 1995 Jeep Wrangler yj. 1982 jeep cj7
Lineman
Damn I just ordered the 3.5 to kit.....think I need too send it back if I'm gonna achieve less then advertised lift.....
Fizzlepop
Fort leavenworth
2018 JL Rubicon
You'll get just at 3.5 on a stock JLUR. More on a Sahara, and even more on a sport.
Tech Support
Waterford New York
rockkrawler.com
If you feel you need more lift you will need a high steer conversion and most certainly a front driveshaft just to name a few of the items. Our lift heights and shock travel specs is based on this. We provide as much lift and travel as you can possibly have safely for the 3.5 lift heights. That lift height is a critical value for JL Owners.
Mojitojlu
New york
Lineman
I have never run rk. I always ran MC....I just checked my spring part numbers too what was posted earlier in this thread and my pt numbers are different.....I don't want to install this kit and have less then 3.5 inches of actual lift..... I think to be safe I'll return my rk lift and go back with MC......just don't want to be disappointed and do the job twice........
Martindfletcher
Martin
San Diego
Ducati 1299s, 2018 JLUR
You may want to search under the original posts name, I think he had other issues once he went to MC.
Mojitojlu
New york
Lineman
Tech Support
Waterford New York
rockkrawler.com
Our 3.5" coils provide 3.5" + 3/8 minus nothing typically for lift and has been well documented on this site. You will not be disappointed, that is for sure. To RK it is not a height game, but it is a ride quality, handling and off-road performance game. For the JL's we strived to stay as close to nominal as possible. As others have mentioned; once you go higher than these coils you will start running into other issues; for example - you will need to covert to high steer, you will definitely need a front driveshaft, and the list goes on and on. That is the point when you really need to open your check book. Not to mention with a 3.5" on a Rubi you can run up 37's up to 39's with full fenders and proper bump stops or 40's with separated rubi fenders. You certainly do not need to go taller! Build smarter!
If you want to be taller, you can swap springs out, we have 4.5" springs in stock, but since we have not released our high steer options, we have not released full systems as of yet and are still in the development and testing phases. It has to be right before we release it.
RK
Fizzlepop
Fort leavenworth
2018 JL Rubicon
The issues I had were due to the stock drag link and tie rod deflecting, not due to the MC lift. I put components of the RK lift back on momentarily to double check, and the problems still persisted. Replacing drag link and tie rod with steersmarts' fixed the issue.
Mojitojlu
New york
Lineman
RK
I understand the drag link flip I have a yeti set up on the way.....taller is not always better I get that....I just want the advertised lift if I put in 3.5 inch springs I want 3.5 inches...I hear of guys putting 3.5 inch springs and getting just over 2.5 inches of lift after all said and done.....maybe I'll swap out to the 4.5 I just don't like doing things twice.....once this lift is in on.....I don't have time too swap springs...........I appreciate all your help......
Cody6597
Elliott
Houston
Jeep JL Unlimited Rubicon
RK
Are you saying with the Rock Krawler 3 1/2 you would not need to switch out the DS?
Tech Support
Waterford New York
rockkrawler.com
It would be strongly recommended if your front shock extended dimension is greater than 29". It is a good idea either way, as any lift over roughly 3" will create accelerated wear on the joint at the transfer case.
Mojitojlu
New york
Lineman
