Tethmes
In that case, what is your oil change interval?20k miles
I rotate every oil change. It is due for its next service.
Tires should be fine then. If it was 10k I would say it's likely cupping as a previous comment suggested. 5k rotations is fine for a ko2 though. Was it always this bad or only a recent development?Every 5k
Hello all.
I have a 2021 JLU with the Sky One Touch roof & Factory Rubicon wheels/tires.
The road noise over 55mph is terrible. I can’t hear myself think. I thought I could live with it but it sounds like a garbage disposal is constantly running.
I purchased a hardtop (not yet installed). after research it seems like that will help but minimally and that a lot of noise is coming from elsewhere.
im considering doing the full sound deadening, the armor lite mats, install the hardtop & linear.
I just don’t want to go down this path and it barely makes a difference. I’m not looking for it to be as quiet as a luxury car, it’s obviously going to be louder just based on the nature of the vehicle.
OR I just sell it and get something else.
Any input?
I have a 23 High Attitude hard top. Noise is not bad. Yes louder then my Ram but not bad at allHello all.
Any input?
Good points. Ill take a picture tomorrow. 27k miles. 4cyl. It drives straight & smooth. Never been abused or any real off-road yet, just the occasional construction site.This post made me laugh! “My jeep is loud, what can I do?” Well that narrows it down. Obviously your first Wrangler. What most people don’t realize the Wrangler is a cousin to the original Willys military 1/4 ton truck. I still consider the Wrangler a a basic 4x4 truck with a bunch of fancy gizmos and gadgets. I can see that you’ve never had the opportunity to own or drive some of the earlier cousins. My Wrangler is quiet as a church mouse if that church mouse was flying up a mountainside with its ass on fire.
My point is that the JL models right from the factory are probably the most capable 4x4 truck ever produced for the general public. Regardless of how many gizmos that FCA installs on the Wrangler, it is not and never will be an SUV. It’s a very capable high clearance multi wheeled vehicle designed for rough off road cross country use, and yes the occasional trip to the grocery store. Is it loud? Yes it’s loud. But “loud” is subjective.
But to answer your question “what to do?” Your tires are probably the issue, especially if there has been any modifications to your Wrangler, like bigger rims/ tires. Mileage, road heat, wear, and suspension out of wack can all contribute to road noise. I suggest you have your tires checked for unusual wear even check your tire size or even rim sizes checking offsets and such. Don’t give up to early.
More info would would help,
Mileage
Picture of the vehicle
Any modifications and so forth.
I only have 8000 miles on my KO2s, but they are quiet. I wonder if you have a wind leak somewhere.Good points. Ill take a picture tomorrow. 27k miles. 4cyl. It drives straight & smooth. Never been abused or any real off-road yet, just the occasional construction site.
No modifications. Its a stock Wrangler Sport S, The previous owner worked at a dealership and swapped the factory wheels with OE Rubicon wheels/tires.
With everyone's comments/questions about the tires, it has me wondering if they are adding to the noise problem.
That'd be great. I ordered a DB meter. The plugs are on my list to check. I think im going to test drive a hardtop with all season tires and get some DB readings aswell. Just need some data to refence off of. If the test drive is also "loud" then maybe I'm just getting oldWait, wasn’t there some issue with reverb from the noise cancelling stuff and the SOT’s, or was that specific to the 392?
Jeeps are loud by nature, but it’s not to say there isn’t a problem with yours. It could be normal noise levels and you just aren’t used to it, or it could be something isn’t sealed properly. As I mentioned, make sure your drain plugs are all in and look at the firewall plug. That firewall plug popped out on mine and I noticed a significant increase in engine noise plus heat on my feet.
I’m on 38” Nitto M/T’s with bumper mounted lights and a roof light bar. I have a hard top with the headliner padding, OEM carpet. While the road and wind noise can be loud sometimes if I have a head or cross wind, it’s easily drowned out with my radio at 16-18 depending on if I’m listening to music from my phone or satellite radio. I’ll try to remember to get some decibel levels for you tomorrow on the highway. That’ll give you something to compare it to.
The SOT fully open/windows up and the corner windows out give a great air flow thru the cabin.Hello all.
Any input?
