Rims and offset, least amount possible
fastfed
GA
21 Jeep
So I was about to order new rims as im rubbing with my 3.5" metal cloak setup, and even hitting the swaybar end links when flexed and turned.
Im not looking to go crazy on price and my buddy has a set of the rocktrix rims . he has a sport with 4.5" backspacing and to be honest I hate the look, I hate how much the wheels stick out.
I was about to order the same ones because well, what choice do I have (not going with spacers), but then I thought what about the 5.5+12mm version? Since I have a Rubicon doesn't the axles already have a little more legnth then the sports version? basically with the 5.5" backspacing work?
Jeep Wrangler JL Rims and offset, least amount possible back
Jeep Wrangler JL Rims and offset, least amount possible bronz
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
AEV uses +25, which I think is a good compromise, especially for wide axle. A Sport can get away with +12 without having the tires sticking out.
fastfed
GA
21 Jeep
yea AEV charges over double the price and they're even heavier. no thanks.
That said Seems Im FU#$@ either way, either I have goofy looking tires sticking way out, or take a chance with a slight offset/backspace and still hit. sucks
libtekguy
Washington
2022 Wrangler Unlimited Rubicon EcoDiesel
As a data point for you, I have 3.5" Metalcloak GC lift and 37s. I'm running Jeep XR wheels and I get no rubbing on street or the trail. Whatever the backspacing of those wheels, might be a good target for you. I also don't like my tires to stock way out, either.
wchrisbarr
William
South Jersey
2024 JL Rubicon
Do you have some photos of your setup and exact tire size? I was thinking of doing the same setup on my ‘24 Rubicon 4xe but was worried the wheels aren’t wide enough and might cause some “vagueness” in steering response on highway.
2nd 392
Ca
XR wheels reportedly 12mm offset. FWIW- no vagueness with 35/12.50’s on stock 7.5”-44mm wheels
libtekguy
Washington
Jeep Wrangler JL Rims and offset, least amount possible 1000005271
I'll snap a photo looking down the fenders tomorrow so you can see how much tire poke I have.
Tires are BFG Mud Terrains, KM3. 37x12.5R17. I'll measure the tire height and width as it sits, tomorrow. I have played around with the tire pressure from 25 to 37 for daily driving. I've found I like the firmness and mpg of 34 psi. Lower PSI was noticably softer, but I was losing about 1 to 2 mpg with it and I notice the Jeep wanted to "pull" to the downward slope side of the road more.
Also, I don't think anyone answered it yet. Yes, you have the wider axles from the factory.
JLfromCA
JL
2019 Mojito! 2 Door Rubicon/2024 Sarge Green 392
I run 37” with 5.25” backspace and fits perfectly
JLeco2022
Anaheim, CA
2022 Wrangler 3.0 V6 Eco Diesel
4.53 backspace -12mm offset, no rubs on 37 K02 with mopar lift
AR172 BAJAAR1727973BSATIN BLACK17X95X1274.53-12mm
Jeep Wrangler JL Rims and offset, least amount possible 20231225_114909
Jeep Wrangler JL Rims and offset, least amount possible 20231225_115214
Jeep Wrangler JL Rims and offset, least amount possible 20231225_115229
Jeep Wrangler JL Rims and offset, least amount possible 20231225_115239
tomk62
Tom
South Carolina
2024 JLU Sahara Anvil, 2019 Cherokee
On your driver's side front wheel, what's the distance from the top of the tire tread to the bottom edge of the fender?
Pig-Pen
Banned Camp
2018 JLU
jabroni
Yes rubi axles are wider than sport/sahara which makes a difference. Rubi can run wheels with more backspacing before hitting anything. All the factory mopar wheels are pretty narrow which helps.
The Last Cowboy
San Antonio, TX
You can get +25 and +18 with Method wheels too.
fastfed
GA
21 Jeep
Thats a sport model right? so with those same rims on a rubicon its going to stick out even further correct?
fastfed
GA
21 Jeep
Yep I know.. Just killing me to spend that much on rims right now.
I hate spacers but I'm so close to just saying screw it and buy 1" spacers and be done with all of this
