Reset dash warning lights after replacing battery?
ODDs
Almost Canada
2019 Hella Yella Sahara
We have a 2019 2.0 eTorque. Right on time for Arizona, the 12v battery died at almost exactly at the two year mark. We jumped it, then drove it to auto parts store. By that time the dash had lit up like Christmas. We replaced the battery, and it is running just fine, but the dash is still lit up.
Is there a reset procedure to clear those warnings? Sorry, I tried searching several times but haven't found the answer. Thanks
Jeep Wrangler JL Reset dash warning lights after replacing battery? hgfjfgj
JeepCares
Auburn Hills, MI
JL
Hey, ODDs. We understand you are looking for insight from your fellow forum members, but should you not find the answers you're looking for, we are in private message to assist.
Kate
Jeep Cares
garyji
Gary
Western NC
Not a 2.0 guy, but do you have 2 batteries, and did you replace them both?? (Main and Aux)
G.
Sheepjeep
Ma
01 xj, 04 Silverado 2500hd
some good obdii scanners can clear those codes, i have a bluedrive and it is able to clear the body control module codes
WranglerMan
Will
Greenfield Indiana
2018 Wrangler JLU Sahara
If the 2.0 has two batteries then the aux battery is a likely cause
ODDs
ODDs
Almost Canada
Yep, I do have the eTorque system and it would be highly unusual to replace that battery. I'm thinking there has to be some sort of reset sequence to clear the warnings.
