Fox Shocks for the JL have arrived at Northridge!
jlsahara
Oscar
AZ
2018 JLU
Oh man, another thing to add to my list.
DeVoTee
Nebraska
12 JKU Rubicon, 17 JKU Sport on Roids, 18 JLU Rubicon, 19 JL Rubicon ordered, RAM, Range Rover
Purchased Mopar springs, bump stops and sway bar links separately and now looking for shocks. One of the complaints about the Mopar Lift is shorter shocks limit articulation. Sooo my question is can I use Fox Shocks that are for 3.5"- 4" lift instead of the 2"-3" lift...
The 2-3" lift measures at Front 16.7" - 26.25" Rear 18.5" - 29.5"
The 3.5-4" lift measures at Front 17.8" - 28.4" Rear 18.9" - 30.50"
Two(2) Door Rubicon not a lot of weight any suggestions would be Greatly Appreciated!
Tech Tim
Summit Sponsor (Level 3)
Tim
Poulsbo, WA
4x4 of all kinds
Part of the Northridge4x4 team
You would need to check the collapsed height with your Jeep.
With the collapsed height being one inch taller in the front, will the shocks bottom out before your bumpstops do?
DeVoTee
Nebraska
So collapsed height would equal shock length (bolt to bolt) minus distance of bump stop to axle?... After new springs are installed?
Tech Tim
Tim
Poulsbo, WA
4x4 of all kinds
Once new springs are installed:
Measure distance between bumpstop mounting face and bumpstop pad (include the bumpstop extension).
**Figure that the OE bumpstop will compress 80% or more on a hard hit**
Measure between shock mounting points.
Subtract from collapsed length
Compare against the bumpstop measurement.
If the shock will bottom out before the bumpstop mounting face hits the bumpstop pad, then the shock is too long.
If the shock can still compress more after the bumpstop mounting face hits the bumpstop pad, then the shock would be fine.
DeVoTee
Nebraska
Thanks Tech Tim!!!
Man-of-methods
Paul
2018 Jeep Wrangler JLUR (His) 2018 Jeep Wrangler JLUS (Hers)
@Northridge4x4
What, if any, Fox or King shocks do you recommend for OEM replacement on a non lifted Unlimited Rubicon? I figure that one of those two brands would offer better ride and handling than the standard red shocks on my Rubi. I’ll be one of the few, if not only, person keeping my Jeep stock.
Thanks in advance.
BigBruse
Robbie
Va
2019 Jeep rubicon
@Northridge4x4
Thanks in advance.
Would like to know the same thing please?
TJ2018
Eric
Orange County, CA
2018 Punk'n JLUR; 2020 Silverado Trail Boss
@Northridge4x4
Thanks in advance.
I'm in the same boat @Man-of-methods . I am not planning on lifting my JLUR either. Might go to 35's once the stock KO2s wearout but that's about it. Personally I'd lean more towards Fox but that's only because I haven't heard much about King.
Watching for reply with bated breath :lipssealed:
Tech Tim
Tim
Poulsbo, WA
4x4 of all kinds
Here are the King and Fox shock PN#s that will fit stock height JLs:
KING Part#
25001-373 - 2018+ Jeep Wrangler JL 2.5 Front Shocks 0-2.5" LIFT - w/ Finn Reservoirs Front Remote Hose / No Adjuster
25001-373A - 2018+ Jeep Wrangler JL 2.5 Front Shocks 0-2.5" LIFT - w/ Finn Reservoirs Front Remote Hose / w-Adjuster
25001-374 - 2018+ Jeep Wrangler JL 2.5 Rear Shocks 0-2.5" LIFT - w/ Finn Reservoirs Rear Shocks Piggy Res / No Adjuster
25001-374A - 2018+ Jeep Wrangler JL 2.5 Rear Shocks 0-2.5" LIFT - w/ Finn Reservoirs Rear Shocks Piggy Res / w-Adjuster
King shocks here: King shocks for JL 0"-2.5" lift
Fox Part#
985-24-171 - 2018+ JL Front Shocks 0"-1.5" Lift
985-24-172 - 2018+ JL Rear Shocks 0"-1.5" Lift
Fox Shocks JL in a package: Wrangler JL Front and Rear Shocks 0"-1.5"
Man-of-methods
Paul
KING Part#
Fox Part#
Thank you very much. That Fox package is a really good deal!!
