Michigan Shockingly Awesome Deal on NEW RELEASE Fox 2.5 Performance Series Shocks
Status
Not open for further replies.
FreedomFur
Elliot
Concord, NH
2021 JLU Willys
JKS Manufacturing
JKS Manufacturing
JKS
Coldwater, MI
2018 Jeep JL
Suspension Manufacturer
I have a jobsite in Coldwater, can I swing by next week and pick up a set?
We could do that. We'd have to process the order in the morning (phone call with payment), and then we could pick them in the warehouse and have them waiting for you at the front desk.
spurly
Zach
Nebraska
2019 Bright White JLUR
Front is 26.67" x 17.76", rear is 28.6" x 18.71"
Interesting. I’m currently running the FOX 2.0 IFP shocks for a 3.5”-4” lift. Both shocks have almost the same collapsed length (within +.2 of an inch) but the 2.0’s are 1.9 inch longer for the front and 1.74 inch longer for the rears. I wouldn’t have thought the collapsed length would be that close.
Mudduck
Jay
Michigan
2021 Willys 4door
Sweet! Thank you!
TEAMSLO
North Las Vegas
22 JLURD
cosmokenney
Cosmo
Loyalton, CA
2019 JLR (2-door)
FOX has released a newly tuned 2.5" Performance Series shock specifically for the Jeep JL.
Only $999.95/set MSRP, does not include Forum Discount (PM me for discount)
Will you have a lift kit + the new 2.5" shocks in a bundle available on your website? I'm looking for the minimum lift that will allow me to fit 37" tires on a two door rubicon.
'23 JLURD (hopefully before Christmas)
Retired/small business owner
I am also confused about the total travel (stroke) of these new shocks vs. other Fox offerings:
FOX 2.5 performance elite DSC (4.5”-6” lift)
Front FOX-883-26-052, 18.34”-30.51”, 12.17” stroke
Rear FOX-883-26-056, 19.43”-32.3”, 12.87” stroke
FOX PERFORMANCE SERIES 2.0 IFP (3.5”-4”)
Front FOX-985-24-179, 17.85”-28.45”, 10.6” stroke
Rear FOX-985-24-180, 18.95”-30.55”, 11.6” stroke
And the new one
Fox 2.5” performance tuned for JL
Front 17.76”-26.67”, 8.91 stroke
Rear 18.71”-28.6”, 9.89 stroke
The new 2.5” performance shocks posted by JKS seem limited by the small stroke even if they are the larger 2.5” bore vs. 2.0 IFP. Is there a reason the stroke is longer for the 2.0 and longer still for the 2.5” performance elite?
JLAFAKASI
Lito
Richmond, VA
JlU Sport S 2019
Is it better to pair these shocks with factory coils or JKS coils?
JKS Manufacturing
JKS Manufacturing
JKS
Coldwater, MI
2018 Jeep JL
Yes, some kits already have them. Look for the FOX 2.5 IFP shock in the shock selection.
JKS Manufacturing
JKS Manufacturing
JKS
Coldwater, MI
2018 Jeep JL
And the new one
Because you're comparing a shock designed for 2.5-3.5" of lift to shocks designed for 4"+ of lift.
JKS Manufacturing
JKS Manufacturing
JKS
Coldwater, MI
2018 Jeep JL
They compliment the JKS coils very well, but can be used with Mopar 2.5" lift coils.
smcneil1972
commerce township, mi 48382
2020 Gladiator Rubicon, 2020 Wrangler Rubicon
FOX has released a newly tuned 2.5" Performance Series shock specifically for the Jeep JL. These new Performance Series shocks feature consistent and fade-resistant performance due to high-quality materials: 2.5-inch aluminum bodies and race-developed main piston with a true internal floating piston (IFP) to separate gas and oil.
The larger diameter valve assembly improves comfort through a wider dynamic range. This allows for a supple feel as velocity increases when transitioning from crawling to fast trail driving:
  • Tuned specifically for optimum ride and performance on larger plus-size wheel and tire packages.
  • The same high-quality aluminum bodies and internal floating piston architecture used in our Performance Series 2.0 shocks.
  • New 2.5-inch diameter shocks have more surface area and increase oil capacity of the shock, allowing for more heat dissipation.
  • Larger diameter valve shims translate to smoother feel: think firmness without harshness, allowing for a softer tune.
  • 50% more piston surface area provides less damping fade and more bottom-out control at higher speeds.
Built-to-last, torture-tested, and race-proven to give a lifetime of great rides.
*Designed for 2-3.5" lift heights.
Are these not the production shocks from the 392 Wrangler?
Status
