Replacement LED Tail lights that support blind spot detection
willcasp
William
Bothell, WA
2018 JLU Sport S
I have the factory LED tail lights that have blind spot detection build in.
The backup lights on these things are so inadequate, it is beyond stupid.
I see their party options that should work, but they do not support blind spot detection,.
Is anyone aware of a third party tail light that provides decent light for backing up, as well as blind spot detection?
Blacksapphirez
Ladson, SC
2020 JLUR
I'll bump since I have the same question.
Logically, I would think the Blind spot module "SHOULD" be able to be separated but things in life are not logical.
blnewt
New Mexico
Just ask @cosine he knows!
willcasp
willcasp
William
Bothell, WA
2018 JLU Sport S
I'd just wire a small light bar tapped into your reverse light wire and keep your OEM LED tails since they're great lights otherwise.
I put one of these on our Sport, and it's been nice, I have aftermarket LED tails that have the same reverse LEDs that are lacking :(
https://www.jlwranglerforums.com/fo...t-bar-on-jl-sport-plastic-bumper-cover.31728/
Thank you for that. I am waiting for the new AEV bumpers to come out, and then I will just add some proper LED lights to the back to light things up.
willcasp
willcasp
William
Bothell, WA
2018 JLU Sport S
You would think. You would also think that back up lights that actually effectively light things up would be a solved problem! Apparently, FCA proves otherwise. Again.
jludave
The Isle of Long
IT Manager
What many people don't realize is that reverse/backup lights are not installed on vehicles to actually light up anything behind you. They are installed as a means for other drivers and pedestrians to know you are backing up. That's it. With the introduction of backup cameras, more and more people complain that their reverse lights don't provide adequate lighting for the camera. Again, they aren't designed with that in mind.
ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
www.oraclelights.com
2019 Jeep Wrangler JL
Automotive LED Manufacturing
Here is a video we made on how to swap the blind spot sensors over.
As for backup lights, adding LED spotlights in your bumper will help give you more usable light if the tail lights don't cut it.
Iamjeepy6
Pablo
Illinois
2020 JLU Sahara, 2021 JLU 80th Ann.
Just saw this, have you tried it and if you did with which brand of light?
Thanks
HJones
Pennsylvania
JLUR
I have the oracle lights and the blind spot monitors do not work properly. Not with shimming, not at all. Customer service is no help.
ORACLE Terry
Terry
New Orleans, LA
Gladiator, Wrangler JL, Bronco, RAM TRX
In what way do they not work? Feel free to DM with any questions and I'll see if I can answer it or get the answers you need.
HJones
Pennsylvania
JLUR
I have emailed back and forth with customer service and their answer was to shim them. If that is the answer the. The design is flawed.
They work intermittently and usually only if a large truck is in the blind spot… but even then it is off and on.
ORACLE Terry
Terry
New Orleans, LA
If the vehicle is lifted, then the angle of the sensor changes. A shim, as recommended, should change the direction of the sensor. The flush mount tail lights really have no other affect on the sensors. Feel free to reach out to me if you want.
