Removing limestone-mud from interior panels
NJRadioGuy
Peter
Northern NJ
2022 JL Unlimited Rubicon
Gentleman of Leisure
OK, so I generally appreciate splashing through puddles on the trail, up until now it was never really an issue. Good power washer and a bottom-blaster attachment, foam cannon and done. But not this time. I ended up bogged to the frame at Redbird SRA in Indiana on trail 3X a few weeks back. The door seals didn't hold and I got about 6" of thick goopy mud inside, all over the carpets, stained the floor and has gotten into everything. I've finally gotten the carpets dry (not clean, just dry) but the painted floorboards are still coated.
But worst of all is the plastic trim inside, especially the textured door panels. I simply cannot clean them, and by now I must have tried a dozen or more different detailing products. Is there any way to thoroughly clean these to like-new condition? I'm at my wits' end over this. Please and thanks.
Jeep Wrangler JL Removing limestone-mud from interior panels 2026-06-04 18.15.53
Jeep Wrangler JL Removing limestone-mud from interior panels 2026-06-04 18.16.22
Terrymo
Terry
2023 JLURXR 3.6 ET
Ok I know I don’t belong in the detailing section but when I have gotten mud on the door panels and it’s left discoloration I’ve had good luck with this and a soft bristle brush then immediately wiping with a terry cloth towel. I’m sure the detail guys will help you out with some better answers. 303 Protectant.
https://www.amazon.com/dp/B00KN0UOEE?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_2&th=1
Wabujitsu
Sarasota, FL
2021 JLUR, 2020 JLU Sahara
Retired US Army
I would try acetone and a toothbrush, and then a vinyl treatment. It worked when I got super glue on the panels.
Reflektr
Travis
Illinois
2025 JLU Willys
Equipment mechanic
Stone based mud is persistent stuff. About like concrete slurry. Solvent-based cleaners may have an adverse effect on the plastic. Crazing, drying, making it brittle and discolored over time etc. Sometimes if you wet it with a spray detailer specifically for plastic, then use a soft brush to work it into the texturing that makes it better. If not, they make a synthetic cleaner specifically for cleaning up concrete and lime dust/by product. I have some at work. What I use is called “Barracuda” and it’s made by a company called 1st Ayd Supply.
Remorseless
NC
Holier Than Thou Internet Bully, Part-Time Online Boy Scout, Full-Time Arson Enthusiast, Napalm Compatible, Not Only The Guy Who Defines What A Jeep Guy Is, But Also The Guy Who Defines What A Jeep Thing Is, Guy Who Has The Authority To Do That
Try baby wipes? They're basically soft steel-wooled plastic wipes, shit's amazing for gently scrubbing stuff that brushes and similar leave behind. They work OK for stainy NC clay if you then follow up with a wet rag to get rid of the citric acid they leave behind.
