Removing dealer slime / silicone dressing from interior?
NWJeepr
Twin Peaks
2025 Wrangler 2-door
  • Thread starter
  • Banned
  • #1
I bought a used vehicle a while back and they slimed the interior with what I think is a silicone-based dressing to make everything shine. It's just slick and gross to the touch.
I tried some mild leather soap/cleaner with some warm water on a terry cloth rag on the dash and it helped a little, but not the "once and done" result I was hoping for.
What works? I want to return the interior plastic back to their natural low-gloss, matte even finishes.
Dale's Jeep
Dale
Michigan
2018 Jeep JL 4door Rubicon
Retired U.S. Army 23 years
Wipe it down again bucket of dawn dish soap and water.
MayThe4x4BWU
Sam
Bartlett, IL
2023 JLURXR
LFG 😅
Is it like that Scotchguard stuff? I bought a Ram 1500 awhile and had asked the dealer not to do it after they offered to a complimentary "protection" package, but the prep techs missed the memo and did it anyway. I had them remove it, with mixed results.
So I ended up using a bucket of hot water, dawn soap and wiped the areas that still had residue. I let the soapy water sit a bit to give it a chance to work in and dissolve or loosen the film.
You might just need another go over or two on yours.
Deleted member 59498
Guest
I looked at a truck with leather seats and it was slimed up so bad I couldn't even sit still because my ass was moving all over the seat just trying to adjust it. Was disgusting and shiny, I was like did you polish the insides?
NWJeepr
NWJeepr
Twin Peaks
  • Thread starter
  • Banned
  • #6
I tried again last night with a bucket of soapy (dawn) water, and it worked a bit better. Thanks for the suggestions.
The interior looks and feels much, much better. Will probably go over it once more for good measure.
GtX
Illinois
2020 JLUR 3.0D
Working for the man.
Polydimethylsiloxane, silicone, has very low surface energy and is hydrophobic (water hating).
Dawn dish soap is/has surfactants that breakup the silicone and surround the droplets so it can be removed with water.
An alternative would be use an organic solvent that is capable of solvating the silicone into solution so it can be wiped away. This is more aggressive and may damage the plastics. The best option is probably isopropyl alcohol (rubbing alcohol). It works OK on silicone but is pretty safe on most surfaces and you. Test in an inconspicuous area. Acetone, methyl ethyl ketone, hexane, xylene will strip the silicone effectively but may also damage the surface.
Bayrat
DA
NY and Fl
2023 Rubicon 392 - 2024 Gladiator Sport BAREBONES
Why do dealers do that :mad:. I completely stopped them this time by demanding that my 392 be parked and locked immediately after the truck dropped it off. I also did the mandatory test drive myself, with the mechanic and his laptop as a passenger. Not everyone wants bling on their vehicle.
NWJeepr
NWJeepr
Twin Peaks
  • Thread starter
  • Banned
  • #9
This wasn’t on a new vehicle. It was used.
Bayrat
DA
NY and Fl
It doesn't matter, new or almost new, it makes a mess and is obnoxious. The dealers should offer it as a free ad on when selling them.
