Removing back up camera?
Dongem
Donna
PLAINVILLE,MA
2020 Jeep Rubicon
I purchased a new spare tire cover for my 2020 Jeep Rubicon. Has anyone removed the back-up camera? I believe that JEEP DId not give me the correct head to remove the screw. It seems the instructions are all for a previous model not 2020. Mine does not look The same.
Thanks
Rdmitch
Ross
Elyria, Ohio
2020 JLUR, ford transit 250, 2017 Wrangler Smoky Mountain Edition
Mechanical designer /contractor and musician
it is a Quarter turn of the little torx screw on the camera housing. The tool should have come with the Jeep, but any hardware, walmart, auto parts store carries these.
Once it’s loose you may have to wiggle,it back and forth a bit. Don’t be too rough, it’s only plastic.
The camera does not come off.....just the plastic housing around it. Your new cover should have a center hole the body of the camera “pokes” thru. After the cover is on the spare the plastic housing may not fit back on. My didn’t so I first left it off.
Sand Flea
Lewes DE
2025 JL Wrangler Unlimited, Sahara
Federal Firefighter, Retired
I moved my camera below the rear bumper.
It now lives just to the right of the receiver hitch.
Photo attached.
Jeep Wrangler JL Removing back up camera? IMG_7564
jludave
The Isle of Long
IT Manager
It should be the T40 bit seen in this pic:
Jeep Wrangler JL Removing back up camera? 1590368405344
spearsmom
Janna
Sandy, UT
2019 Wrangler Rubicon JL 2.0L Turbo, 2016 F350 Diesel, 2010 Mazda 3
Photo attached.
Can I ask how you did this? Is there some kind of a kit? I have a Smitybilt Intelligent rack that needs to mount in my spare, but don't want to lose the camera. Thanks
Sand Flea
Lewes DE
No kit that I am aware of.
My JL is a 2018 model year. When I ordered it I told the dealer that I needed 2 things...
1.). a front mount 2" receiver hitch for the front to mount my fishing rod rack
and
2.). The camera needed to be moved to accommodate my Thule bike rack which also doubles as sand chair and umbrella rack when I drive the beach.
The dealer was told these were my requirements to buy and needed to be done prior to my taking ownership.
They took the JL to a shop local to me, and they did everything. This shop does all of the dealers 'custom' work.
Now in July of 2018, nobody had anything to fit to the new JL's. This shop found one of the first front receiver hitches, and fabricated the camera mount.
Park Sense doesn't like 'seeing' the bike mount on the rear, but that is easily remedied by turning Park Sense off when the rack is installed.
I've attached some detail photos.
Jeep Wrangler JL Removing back up camera? IMG_5985
Jeep Wrangler JL Removing back up camera? IMG_5991
Jeep Wrangler JL Removing back up camera? IMG_5983
Jeep Wrangler JL Removing back up camera? IMG_6028
Jeep Wrangler JL Removing back up camera? IMG_6173
MEGAS
Megas
Vancouver, BC
and
Can you show us the "rear view" from the camera?
Sand Flea
Lewes DE
Sure. Had to pull out of the garage, but you get the idea.
Jeep Wrangler JL Removing back up camera? IMG_2512
Jeep Wrangler JL Removing back up camera? IMG_2513
Jeep Wrangler JL Removing back up camera? IMG_2514
