Remove front rock guard/air dam?
TJHUB
Terry
WI
2021 JLU Sport Altitude
I know many have removed the front rock guard/air dam, but is there a good reason to leave it on? I have a Sport Altitude with the stock plastic bumper. I'd like to remove the plastic and metal pieces.
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
They're only there for gas mileage. Ditch it if you want. If you love spending money on gas, then you will love that mod ;)
dchemphill1
Nebraska
2020 Wrangler Rubicon Recon
School Administrator
Beside fuel economy....If you live in snowy area it can lead to snow getting up in engine bay. Changes the airflow so it can swirl up and collect.
TJHUB
TJHUB
Terry
WI
It's not for a looks thing, and I don't really care about gas mileage (much). I'm getting it ready to flat tow behind my motorhome, and the install of the base plate for towing really hacks those pieces up. So I'm wondering if I should just leave them off?
jmccorm
Josh
Tulsa, OK
2021 JLUR
Systems Engineering
A new front bumper required the removal of my air dam, leaving a vulnerable path to the sway bar motor. (Low risk, moderate impact.) I'm checking into a compatible skid plate, but I'm wondering how much more I'd spend getting someone to craft a replacement that act more like the original air dam.
Aerodynamics might be of marginal improvement, but I think the topic is picking up interest right now.
Yogi
Port Dover, Ontario, Canada
GM, P.Log, CITT, 310T
I got one of these from Oracle. Solved my problem.
Jeep Wrangler JL Remove front rock guard/air dam? 1649447408217
JP29
Zach
Olathe
2020 JL Sport
We both know you need one of these ;)
So excited to put mine in next week and actually get some use out of my aux switch install!
FreedomFur
Elliot
Concord, NH
2021 JLU Willys
Just flip the motor up….moves it up by at least a few inches. Took me about 20 minutes with my bumper still on.
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
BBQ prophet
I need to cut the stupid frame horns off. I moved my sway motor up years ago when I put my bumper on. It's close to my winch plate, but hasn't hit it yet.
jmccorm
Josh
Tulsa, OK
2021 JLUR
Systems Engineering
Jeep Wrangler JL Remove front rock guard/air dam? 1649448959473
YES. Show me when you do!
You don't know how on-target this suggestion (in particular) is right now. It's a really good place to put the fog lights, right? But I've got to pump the brakes and not go too far ahead of myself without developing a concrete overall vision of where I'm heading with everything.
I've arranged for some consultation time with a very sharp small-crew custom design shop in my area... two months from now. It's an awful wait to onboard a new customer, but if it's justified... it's justified.
JP29
Zach
Olathe
2020 JL Sport
I think it's a convenient location for lights, fogs or pure whites like what I got. Since I don't crawl I'm not so worried about a pod getting smashed, and it'll look a lot better than the chunky air dam. I watched Oracle's vid on install last night (still have the 30 second riff of chugging heavy metal on repeat living in my head rent free) and it looks dead simple, need to figure out what to do about bypassing their goober toggle switch though. Instructions might clear that up, I haven't popped the box yet since I'm on all weekend. I hear you on the wait, went through the same hurdles last year with my color matched half doors. In the end, the local shop did a fantastic job, well worth the wait. But it was a hefty chunk of change.
jmccorm
Josh
Tulsa, OK
2021 JLUR
Systems Engineering
My intent, if going with those lights, was to use the vehicle's own fog light circuit to activate a relay that then fed the lights through an existing AUX or fused to battery. Not a sure-thing as far as the BCM accepting it without faulting, but I figured it could probably be quieted down with JScan.
Yogi
FWIW the amber lights are plenty bright. I would think the white lights would be tremendously bright.
I would think that it could be adjusted up and down by using washers on either the top or bottom, however mine is just right for me.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
After installing the front and rear Antirocks, I was also able to delete the steel skid plate that only served to protect the edisconnect motor. I was originally planning on cutting the tusks off flush with the frame rail, but glad I was delayed when just a few weeks later I realized I needed them to mount a Warn winch plate. Also spent more time looking at the tusks when installing that plate. Even if I didn't need them for the winch plate, I still wouldn't cut them completely off, but more of an abbreviation so they would protect the sway bar bushings from possibly getting sheered off or crimpled. My thought is that one would feel a bump to the tusk and know to back off, but the sway bar bushings would be wrecked before feeling that a back off was needed.
