Remote start only
Karrumba
Angel
2018 JLU, 2010 JKU
If the brake switch wasn’t registering, it wouldn’t shift out of park. I’d bet money the OP isn’t pushing the pedal hard enough on cold starts due to the lack of vacuum assist.
I wish I had known I needed to squat 500lbs to start a Jeep before I bought it.
elf883
steven
NY
2024 jlu willys anvil
stationary engineer
how old is the jeep ? have you checked the battery voltage , how is your battery / batteries ?
i can probly say one or both of your batteries is on its way out . does your start stop work when the jeep runs ?? any other weird issues ?
i would check the battery/batteries
mwilk012
2018 Ocean Blue JLU Rubicon
Service
Brake switch being out of calibration will do that. Everything else will work fine. Try this: remote start it, then shut it off. Immediately attempt to restart it with the normal push button.
Karrumba
Angel
2018 JLU, 2010 JKU
Jeep is a 2018. I replaced the main battery and tried the F42 bypass of the aux battery. Tried starting with the start button after each and neither made any difference.
Other than this quirk the jeep functions just fine and doesn't even display any error codes on screen and Start/Stop still functions.
Xorak
TN
2020 Hellayella Sport, 2023 Reign Sahara
That doesn't have anything to do with the problem. You may as well say that you locked the doors and it still doesn't start.
Press the brake harder.
Karrumba
Angel
2018 JLU, 2010 JKU
I tried your suggestion but it still didn't start.
One thing I didn't mention is that you can hear a noise like the starter is trying to engage.
Karrumba
Angel
2018 JLU, 2010 JKU
I replaced the main battery and bypassed the aux battery and it still didn't start.
mwilk012
Service
Alright this is good info, still doesn’t make a whole lot of sense though. Is your remote start factory or aftermarket? Any security systems or trackers spliced into the start circuit?
mwilk012
Service
If you sit in the Jeep with the key, and press the start button, will it cycle from off to acc to run?
Karrumba
Angel
2018 JLU, 2010 JKU
So it's factory remote start and does not have an aftermarket security system.
Karrumba
Angel
2018 JLU, 2010 JKU
It will cycle through and like I said make a sound like the starter is wanting to engage but but it does not turn over. All I get is push brake to start message.
AC77
AC Abegian
Los Angeles
Autobody , singer-songwriter
Check the brake switch behind the pedal. See if it’s lose or broken best way would be take one off a friends JL and swap it. Or buy one only thing is some places don’t refund electric parts
You can also check the resistance and check the connector behind the brake switch /neutral safety switch
Karrumba
Angel
2018 JLU, 2010 JKU
Great idea. I did check for loose/disconnected brake switch but didn't think to check resistance.
mwilk012
Service
There are a lot of relays that click when attempting to start, including the auxiliary PCR which is a pretty big one. What’s weird is that the wiring flow path is exactly the same for a remote start and a normal start, both are signals sent to the radio frequency hub.
You’re going to need a scan tool or to just take a bunch of guesses at this point.
Jeep Wrangler JL Remote start only CAFEDF7A-CBDB-4FC2-A456-FCB9697B4AA2
