Reid Racing Steering knuckles
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
thats what the dude said and when I called RK about lengths kind of makes sense. My bodies are 8”, I believe the short ones were 7 or 6...when you get a chance measure the body on yours for shits and giggles.
Yeah, it's been awhile since I had a tape anywhere near them. I'll do that in the daylight tomorrow.
Roky
Roky
The shorter ones are 7” between the jam nuts. My shocks are at 31” extended and I’m adjusted to 10-3/4” eye to eye. Assuming yours droops a little more with the 6 pks, I’d say you’d be good at 11.5”.
Fully stuffed I was hitting inner fender, but that was mostly because I shimmed them out to not rub on resi hose. I’ve since notched for hose, no more issues. Also I turned the bolt around on the top to get a little extra clearance.
Your gonna love these , there is essentially no difference in droop hooked to the sway bar or unhooked. Here’s couple pics of ride height, stuffed, and extended.
Jeep Wrangler JL Reid Racing Steering knuckles E90856D4-75FD-4404-8E77-8D0AF15986FF
Jeep Wrangler JL Reid Racing Steering knuckles 27942E8D-2119-4764-8027-31D0BF9876C3
Jeep Wrangler JL Reid Racing Steering knuckles E1F38581-BCB1-4DC4-B2DF-08D1DC4E6D9E
Headbarcode
LI, New York
That's where my confusion was. They look like they're more than 1" difference on their product pages. They mention lift heights, but not their own lengths.
I have the smaller 7's, and are extended as far as they'll go before not have enough threads engaged. I could definitely use that extra inch, and it has nothing to do with my being Irish. The flex of the 6-packs is ridiculous. I may even switch to the 4.5" lift coils that Metalcloak is supposedly coming out with. These shocks and the upper relocation brackets make it too easy to unseat the springs.
And, pics as promised.
Edit to add: I measured the total length of my adjustment at roughly bolt centers, which has it at 11.25".
Jeep Wrangler JL Reid Racing Steering knuckles 20210204_134348
Jeep Wrangler JL Reid Racing Steering knuckles 20210204_134758
moodywizard
Lyle
2019 JLUR
Thanks for the info guys, yeah mine are 8.25 body and a lot of thread on the heims. When I did my hydro bumps I set them to almost max out the compression on the 6 paks disregarding sway links and tire rub as I can dial that in if needed. In hind sight I should have connected the sways and installed the tires but was pressed for time and didn’t have the links on hand at the time. With the hydro bumps I must of gained 1-2” compression. Going to play with the rear next, the uptravel really helps when out in the desert.
KansasJL
Kansas
2019 Sting Grey JLUR
I’m going to have to unfollow this thread. I feel like I’m getting sucked into the rabbit hole and I don’t want to cry when I look at my credit card bill...
Moto_21
Moto_21
Erik
Corona
2018 JLU Sport
Maintenance
The final stage is acceptance, just let it happen
KansasJL
Kansas
Very much so. The steering TSB is happening on Tuesday and then the 37’s go on... and then... well it might be to late already
moodywizard
Lyle
2019 JLUR
Haha love this thread
I’m just waiting for you guys to upgrade to dual shocks in the front so I can get dibs lol any of you running black kings? Yes I know I’m picky
KansasJL
Kansas
I can’t justify coilovers. I’m in the middle of flat Kansas
Moto_21
Moto_21
Erik
Corona
2018 JLU Sport
Maintenance
So who wants to buy mine then? ?
