Regen indicator ... w/o a gauge
Grayhound
Michigan
Jlurd
You obviously moved the transmission to park for the completion of the regen cycle. Did you verify that the soot level dropped to 8% when it stopped the cycle? The reason I ask is that I've been lead to believe that if you stop and move the transmission into park, the regen cycle stops no matter what the soot level is at.
I'll duplicate your stop-n-park process at sometime in the future, but for now I'm concentrating on collecting data without stopping. Without any codes, the dealership is lost. I'm working to get some time with a tech rep to explain why my DPF fills up so quickly.
What oil are you using? I went to Motul last time and noticed much slow soot build up.
Then had an oil leak fixed at the dealer and they changed the oil back to penzoil and il watching my soot build up faster in the dpf.
Deleted User 38384
2023 JLRUD with a few regen problems. At ~9500 miles I had to limp in to the dealer for a forced regen ... dash lit up like a Christmas tree. Then at ~10,000 miles, while on the way to Moab, I limped into another dealer with a turbo controller code. They replaced the turbo. I found a number of mechanic mistakes with the repair, so have been running trails locally until I'm comfortable that all mistakes have been corrected.
Bought an iDash Data Monster to follow the soot build-up and regen cycle. The Off/Pas/Act signal is useless because it's never steady ... keeps flashing back and forth between two ajacent stages. Thus, I use the DPF inlet temp, with an active alert set at 1000 degrees F, to signal when a regen cycle starts. My Jeep hits 1200 to 1250 degrees F when in the middle of a regen cycle.
My last four regens have averaged 110 miles between. That's a mix of 45mph in town with stop lights, trail riding, and expressway driving at 75mph. Even though the PID says average milage between regens, the Banks tech says it reports the mileage between the last regen and the one before that. Trying to figure out if it measures from the start-to-the-start of those regens or the finish-to-the-start of the current one. Banks isn't great about providing info on what is acturally being measured for many of the PIDs.
Caught a regen while in the 45mph, with stop lights, area of town and found that the data supports the idea that the idle RPM is raised during a regen. In fact, it goes up from a normal 650rpm to 850rpm. The attached graph shows the engine RPM in blue The start and stop (from another graph) of the regen cycle in orange vertical dashed lines. The red horizontal lines show the engine at 650rpm when stopped at a traffic light. And, the green horizontal line show the engine at 850rpm when stopped at a traffic light during the regen cycle.
So, if you don't have an add-on gauge and wonder if you're in a regen cycle, simply stop with the Jeep in gear and check out the engine RPM ... if it's at 850, then you're in a regen cycle.
I cut off my exhaust pipe a while back to delete the muffler. And then at a separate point I cut out the tub in the cargo area and replace it with aluminum sheet panel that I screwed in place. And then at a separate moment I put a horse stall mat over the cargo and back seat area.
Not much smells get through, but some do. It's not as noxious as when I first had the tub removed and nothing covering that giant hole in the cargo area. I almost killed myself once two winters ago not realizing that when it goes through a regen it starts dumping what basically comes out to bleach into the cabin with my setup at the time.
At this point, when the vehicle's moving it's not so bad, I can only smell a little bit of that noxious smell. Enough to let me know that it's happening, not enough to have me rolling down Windows gasping for air. However when the vehicle stationary and it's going through a regen I can smell a little bit more of that noxious sulfur bleach smell. Still not enough for me to have to roll down the windows, but definitely a little more pungent.
I'd be curious to see how often I regen. I'm sure it's a lot, I've never seen a active regen, only ever had passive regens. But I also do like 80% highway driving, so I'm not super shocked by that.
Interesting factoids, I'll keep an eye out for that 850 RPMs while idling!
