Red Neck Ram hydro assist steering
1996cc
Oregon
22 JLUR 392
He as anyone added the Apex steering pump boost kit or a cooler to the system yet? I want to boost my pump, but don’t like Apex’s cooler.
beckbuilt
Jon
Ut
21 392, 18 JLUS
I pulled these from a Light Bright video.
Very helpful! Thank you. My Apex boost kit is on the way. This is the next step for me. Seems straight forward as long as the holes go into the proper cavities.
beckbuilt
Jon
Ut
21 392, 18 JLUS
Look from the bottom to make sure you have clearance
This helps a lot! Thank you. If it’s not too much hassle would you mind snapping a pic of the other fitting?
Glamisfan
SoCal, 30 minutes from Glamis
2020 Sting-Gray JLUR
What size pipe thread to screw into the steering box? I’ve read 1/4” NPT, but 3/8” NPT makes more sense to me.
beckbuilt
Jon
Ut
21 392, 18 JLUS
It’s 1/4 NPT, pipe sizes are strange, it measures around .50” dia.
The fitting that will screw into the female 1/4 NPT will have male -6 JIC on the side the mates with the hose. -6 JIC is used for 3/8” hose. That’s where the sizes are coming from.
GSLSE21B
Fair oaks
2021 jLURD
Jeep Wrangler JL Red Neck Ram hydro assist steering 1DCB4960-BD20-4153-8385-5F26EFE1DDF2
My 3.0 intercooler pipe is in the way of the picture . You can tap the top and bottom in two different areas depending upon your clearances
beckbuilt
Jon
Ut
21 392, 18 JLUS
part number #C5205X6 1.50-2.00 each
Awesome! Exactly the info I was looking for. Thanks for that last pic and the part number. That’s what I’ll use.
I hope to be drilling next weekend!
Glamisfan
That number is showing it’s for a 3/8 NPTF x 1/4 JIC at Graingers. Shouldn’t it be
1/4 in x 3/8 in Male x Male NPTF x JIC 7,000 psi Rigid 6W435
Upsidwn
Mat
NE, Oh
2021 JLUR
You guys are awesome with all the part numbers and pictures! I'll be doing this at some point in the near future!
Glamisfan
For those of you that have done this yourself, do you think the hole for the upper fitting could be drilled onto the side of the steering box instead of the very top? My OEM lines go right over the top of it and there’s not a lot of slack in them. I’d rather not have a rubbing issue if I can avoid it altogether.
beckbuilt
Jon
Ut
21 392, 18 JLUS
You can reposition the hardlines when you loosen the inverted flare nut on the box. The top is the best place to drill from what I’ve seen. You don’t want to mess up the bore where the piston seals at that end.
Ptevo03
Preston
1979 cj7 and 2018 Rubicon
This thread has a lot of good info I'm just wondering if you Can u tell us which port on the box goes to switch side of the ram please?
