Rear storage basket
Cllowe
christopher
Tennessee
2020 2 door jl
Is there anyone that makes a rear cargo basket for a 2 door? I have my seat out and thought the one for the 4 door would work but the mounting is different.
  • Like
Reactions: jal
Cllowe
Cllowe
christopher
Tennessee
2020 2 door jl
Yeah that is one I have on the radar. I would like a slotted bottom to it would be easier to stead gear down.
TxJeepers
2025 JLUR '41
Cllowe
Cllowe
christopher
Tennessee
2020 2 door jl
I found a different thread and it was spot on. If you’re handy in the garage you can reverse the mounting brackets and drill 2 holes. After that the 4 door version will fit but it has to be the surface mount not the roll bar mount.
Jeep Wrangler JL Rear storage basket 900A787E-6190-4BFC-A237-8914C41C82FB
Jeep Wrangler JL Rear storage basket 1F16A86D-2776-4630-BA99-EF4E0BC4F90D
Gmanjeeper
Arkansas
2022 JLR
What brand is your rack. I ordered a no name brand (which I can return if it does not work) and I am going to try to install in my 2 door between the roll bar posts and the back of the front seats. (My back seat is totally removed). As one other guy did, I hope to be able to attach
a ripped 2x4, or maybe even a 1x4 with the existing hard top bolts and then attach the rack brackets to the 2x4 or 1x4. I am pretty sure the existing factory hard top bolts are M8 x1.25 so I will need a couple of these bolts only at least 3/4” longer, depending upon the thickness of the board I use. I am wondering how you installed your rack.
Cllowe
Cllowe
christopher
Tennessee
2020 2 door jl
I ended up turning the rack 180 degrees and had to redrill the front holes.
wheelsfeels
Rock Sponsor (Level 1)
Anton
Houston, TX
wheelsfeels.com
Jeep Wrangler Sport JLU 2020
I have installed two shelves to have an opportunity to adjust them according to my needs, also made some additional side compartments (around 1 sq. ft. each).
Jeep Wrangler JL Rear storage basket 11-organizer-for-jeep-wrangler
Jeep Wrangler JL Rear storage basket 2023-12-05 16-02-19
Jeep Wrangler JL Rear storage basket блок3
