Rear side impact question
mqu02
Nebraska & Idaho
2021 JLR
Industrial Engineering
My son was just driving my '21 JLR, it was snowing, and apparently slid sideways into something that primarily impacting the drivers rear wheel. It could have been a whole lot worse, but broke the rim, and left a scrape on the fender.
Other than the obvious damage to the rim, what should I be looking for, and what are the odds something else is damaged?
PS. No, I don't know how this tire is holding air, let alone how he got back to the house with it. If that would have been me it never would have.
Jeep Wrangler JL Rear side impact question IMG_8602
Stetson
Salt Lake City
2019 JL Sahara, 2023 392 Rubicon, 2020 GMC 3500 Denali
Project Manager
That looks like a pretty hard lick. I would inspect the rear suspension (shock mount, spring mounts) and the driveshaft and make sure nothing got tweaked.
if not, I would say send him to church because he is damn lucky
JeepinPete
Pete
PA
'19 Mojito JLUR
Mechanical Engineer
I bent an axleshaft that way when I was young. I'd jack up that corner and spin the tire to see if it is wobbling.
mqu02
mqu02
Nebraska & Idaho
2021 JLR
I just got home and am going to look into it shortly. I can see it moved the axle right a little bit, so I’ll have to see what all is bent. More to come.
mqu02
mqu02
Nebraska & Idaho
2021 JLR
Update: I just tore into it and the rear track bar appears to have saved everything else. I would think if it bent the axle I'd see wobble on the brake rotor, but it seems to rotate pretty true. All in all he was pretty lucky and this could have been a lot worse.
I will probably replace the rear track bar with an adjustable one, as they aren't that much more expensive than stock.
Jeep Wrangler JL Rear side impact question IMG_8610
UNC Rubicon
Bret
Kernersville, NC
2019 Billet Silver JLUR
Check the rear track bar bracket for cracks as well. When I had my 2019, I got t-boned back in 2021. The truck hit my drivers side rear wheel and it sheared off the track bar bracket.
mqu02
mqu02
Nebraska & Idaho
2021 JLR
Thanks for the heads up. I just took a good look at it, and fortunately it appears fine. I also looked over as many other mounting points as I could see and all look ok. I’m hoping the track bar sacrificed itself to save others!
Spank
I slid off a rock and into the side of another on a wheeling trip and folded my rear trackbar the exact same way, but had the same result. It took one for the team and everything else was fine.
azwjowner
Phoenix
Minor point, but if you're lifted, a relocation bracket with the stock bar will provide better ride quality than an adjustable track bar. Only by moving the mounting point can you compensate for the raised roll center of a lifted vehicle.
mqu02
mqu02
Nebraska & Idaho
2021 JLR
This is interesting, and it makes me think an ultra-strong track bar might not be a great idea. Sacrificing the track bar is a whole lot easier repair than anything else damaged along the way.
mqu02
mqu02
Nebraska & Idaho
2021 JLR
I’ve read about these but haven’t looked into them. I put a slight lift on the rear because from the factory mine was really high in the nose. I ended up with stronger springs and a half inch spacer, and this is a 2 door.
