Rear Camera Not Working - Blue Screen
Billet_JLU
Austin
Ohio
2018 JLU sport s 1999 Cherokee Sport
Mechanical Engineer
Hi there, were you able to fix the issue with the replacement wire? I am getting the exact same issue after installing my tire carrier, black screen, camera system unavailable. A new camera did not work. Also do you know the part number for the replacement wire?
Yes my backup camera is finally fixed! The part number is 68432105AB I ordered from allmoparparts.com.
jason0341
Jason
2020 2.0L Rubicon
I’m fixing to order a Teraflex Alpha HD carrier. What’s the secret to keep the camera working?
Billet_JLU
Austin
Ohio
Mechanical Engineer
I’m fixing to order a Teraflex Alpha HD carrier. What’s the secret to keep the camera from not working?
To keep it working, use a small flat head screwdriver in the spot that the stock camera cover went into while pushing everything else out. I’d recommend taking your time so you don’t have an added cost the camera stuff cost me an extra $130 or so on top of the carrier price.
jason0341
Jason
2020 2.0L Rubicon
Instead of using a hammer to hit the studs?
Billet_JLU
Austin
Ohio
Mechanical Engineer
You need to use a hammer to hit the studs and use the screwdriver to push the camera out. Work them both out simultaneously. What happened for me was I knocked the studs all the way out but the camera stayed in damaging the wire and camera. Maybe you’ll get lucky and the camera comes out with it. It’s easy to do, just need to be careful.
jason0341
Jason
2020 2.0L Rubicon
Makes sense. What size tire are you running and which stud option are you using? I have the factory plastic rear with a 315/70/17.
Billet_JLU
Austin
Ohio
Mechanical Engineer
37x12.50r17, I used the top spot. For the 315’s the middle option would probably work. I’d mount it up loosely and check your clearances before you torque everything down.
Chainringtattoo
Grand Junction, CO
2021 Wrangler Rubicon ecodiesel
Bringing this old thread back to life. I just moved my rear camera into the Motobilt tire carrier and license plate relocation bracket and I'm getting the blue screen. Funny thing is, the front camera doesn't work either now. I can't even select it. Nothing happens when I push the button. I was pretty careful separating the wiring but did cut the camera wiring a bit but didn't even get into the sheathing underneath. It was barely a knick. I wrapped it back up. I tried the battery trick with no luck. Also tried turning camera on and off with my Tazer. Before I order new wiring and camera I want to see if there are any new solutions out there.
JeepCares
Auburn Hills, MI
JL
Hi Chainringtattoo,
Sorry to hear you're experiencing this! If you decide to bring this to the attention of your dealer for an official diagnosis, feel free to send us a PM for additional assistance alongside them.
Sarah
Jeep Cares
Zanner1718
Suzie
Wisconsin
'18 JLUR, '11 GMC Yukon Tex Ed, '22 Cadillac CT5
Just bought a 2018 JLUR with 3600 miles on it a couple weeks ago, and now I'm getting this blue screen too. All was working beautifully until this morning backing out of the garage. What I'm reading is there is a software update required, but the dealership assured me all software was up to date. So there's a wiring issue maybe? I don't know anything about vehicles, but hubby could probably figure it out if it's just a wire issue. It did come with 37s and lifted, so maybe the big spare tire is causing this issue? I don't know where to begin. I just want to drive my Jeep longer than 2 weeks with no issues. Am I asking too much?
JeepCares
Auburn Hills, MI
JL
Hi there, Zanner1718
We're happy to take a look into this for you! Feel free to send us a message with your VIN. From there, we'll verify the software level that's running on your Jeep and check for any internal resources to address this.
Steph
Jeep Cares
PeterKH
PeterKH
Cambodia
Jeep Wrangler Unlimited Willys 2020
Hello @JeepCares I have an issued yesterday on my JLu Willy's 2020 with the screen didn't pop up anything once i start the vehicle, had try turn off and start back many times but the screen still dead. But after run a mile and it just start slowly pop up. Is there i need to update any software too?
JeepCares
Auburn Hills, MI
JL
Hi PeterKH,
We can check this out for you. Feel free to send us a private message with your VIN to get started.
Steph
Jeep Cares
blink9cd
Billy
Virginia
'21 JLU Willys
Realize this thread is old, but I just did the switch to the Teraflex tire carrier tonight and am having this issue with the backup camera too. Same issue, blue screen with the text. My brake lights still work well.
@ale70 did you fix your issue? How about you @W4YLON or @Chainringtattoo? @Billet_JLU it was definitely the cable for you? I have a 21 with the pink connector.
Not sure what happened. Maybe it was when hammering stuff out something got ripped or bent? I think it did come out abruptly and the cables could've been pulled. Visually they looked ok.
blink9cd
Billy
Virginia
'21 JLU Willys
In case anyone finds this, it turns out the answer is it was getting dark and I had accidentally routed the camera wire wrong and it got pinched and cut :( Had a to buy a new wire set and install. Everything is good now on my end.
